johnjamesjacoby
RPi 4, 8Gb, Ubuntu 20.04, PoE Hat Fan Speed Control
Wed Jun 10, 2020 9:49 pm
Hey there. First new topic; long time anonymous lurker. Apologies if this is not the correct forum.
I recently installed Ubuntu 20.04 on an 8Gb Raspberry Pi 4, and am powering it via an official PoE Hat. It appears to be working correctly, except the dtparam overrides in /boot/firmware/usercfg.txt do not appear to have any effect.
# PoE Hat Fan Speeds
dtparam=poe_fan_temp0=65000,poe_fan_temp0_hyst=5000
dtparam=poe_fan_temp1=67000,poe_fan_temp1_hyst=2000
The above overrides work correctly in Raspberry Pi OS in /boot/config.txt on several Raspberry Pi 3B's and 4's.
Any ideas?
wildestpixel
Re: RPi 4, 8Gb, Ubuntu 20.04, PoE Hat Fan Speed Control
Tue Jun 16, 2020 7:16 pm
I'm actually seeing some odd behaviour from my POE HAT (albeit I replaced the fan with a Noctua 5v). I'm attributing my odd behaviour to new kernel or possibly bootloaders introduced over the last few weeks.
My dtparam settings no longer have the desired effect. If I don;'t set anything, the fan always seems to be on, and if I set something (like the example you have given) the fan seems to activate at 50 celcius with an hysteris of 2 celsius, so on my Pi 4 4GB 32 setup this ting is on and off like a yoyo whilst idling at the desktop (just serving vnc)
Something changed as I had previously for a long time had these settings running perfectly (i.e. since about August last year)
Some observations are made here : https://github.com/raspberrypi/linux/issues/2715
much solution-ness - https://www.wildestpixel.co.uk
wildestpixel
Tue Jun 16, 2020 7:27 pm
Looks like from some testing that adding the line at the beginning fo this section so that for examplke your settings read :
dtoverlay=rpi-poe
dtparam=poe_fan_temp0=57000
dtparam=poe_fan_temp1=60000
dtparam=poe_fan_temp2=63000
dtparam=poe_fan_temp3=66000
dtoverlay=rpi-poe
* seems to be the magic bullet *
Return to “Ubuntu”
