arq.diogo
Uninstall Teamviewer Host [Ubuntu]
Wed Jun 10, 2020 6:47 pm
I need help to unistall Teamviewer Host from my Raspberry Pi 3. It runs Ubuntu Mate.
I've tried via terminal something like: sudo apt remove teamviewerhost
Not work
arif-ali
Re: Uninstall Teamviewer Host [Ubuntu]
Wed Jun 10, 2020 8:26 pm
You might want to check on the command line on what the package is actually installed.
Maybe first try "dpkg -l | grep teamviewer", and once you find the one you want to remove, you should be able to then remove by running "apt remove <pkg_name>"
You can also find me on IRC: arif-ali@freenode
Current rpi's:
3 x rpi4 4GB with Ubuntu 20.04 64bit
1 x rpi4 8GB with Raspberry Pi OS (beta FW for booting from SSD)
Linpack result:
14.401 GFlops, https://gitlab.arif-ali.co.uk:8543/snippets/26
arq.diogo
Wed Jun 10, 2020 11:57 pm
Thank you man, it was "teamviewer-host", thats why it does not work before...thank you
Return to “Ubuntu”
