cmrincon
Help my code to look better
Sun Jun 07, 2020 6:02 pm
Hi! today i read the google style guide (https://google.github.io/styleguide/pyguide.html) and i started to make some of my code to look nice. But this function it still looks awful. Roast my code, all tips all welcome
def read_config_file(config_file_path):
    """Reads and parse a config file.
Args:
        config_file_path: path to the file to parse.
Returns:
        A dictionary with the mapped settings.
    spells_dictionary = {}
    line_number = 0
    with open(config_file_path, 'r') as config_file:
        for line in config_file:
            line_number += 1
            uncommented_line = line.strip().split('#')
            if len(uncommented_line[0]) == 0:  continue
            splited_uncommented_line =  [x.strip() for x in uncommented_line[0].split(',')]
            if len(splited_uncommented_line) != 2:
                print("ERROR: incorrect line format".format(cfgPath))
                continue
            try:
                spell_id = int(splited_uncommented_line[1])
                spells_dictionary[spell_id] = splited_uncommented_line[0]  #Splited_uncommented_line[0] = spell Name
            except valueError as e:
    return spellsDict
jahboater
Re: Help my code to look better
Sun Jun 07, 2020 7:01 pm
Even for something simple like this, I would put the protected code on the next line:
  continue
Is Splited spelled correctly?
Possibly some blank lines separating distinct logic blocks or sections.
Pi4 8GB running PIOS64 Lite
Sun Jun 07, 2020 7:43 pm
It's a trick question.
It is not possible to make Python source code look nice. :)
Before trying to make it look nice I would make it at least work. That function returns a non-existent variable spellsDict.
I would remove the confusing comment "#Splited_uncommented_line[0] = spell" which looks like it is dead code that has been commented out.
I find the ugliest part being variable names like "splited_uncommented_line". There must be something shorter and sweeter. Like "words" or "fields"
I don't know if it's required by some Python documentation standard but I would move the comment block at the top to outside the function so as to not break up the code.
Something like:
Args:
Returns:
    spells = {}
    line_number = 0
            line_number += 1
            words =  [x.strip() for x in uncommented_line[0].split(',')]
            if len(words) != 2:
                continue
            try:
                spell_id = int(words[1])
                spells[spell_id] = words[0]
    return spells
kaksi
Sun Jun 07, 2020 7:47 pm
It seems to me that line_number is not used.
jahboater
Sun Jun 07, 2020 7:58 pm
+1
I think a docstring must be just after the function header.
cmrincon
Sun Jun 07, 2020 8:32 pm
Thanks you!
Heater wrote: I don't know if it's required by some Python documentation standard but I would move the comment block at the top to outside the function so as to not break up the code.
https://google.github.io/styleguide/pyguide.html Chapter 3.8.3 . Docstring requires it.
Heater wrote: It's a trick question.
It's very difficult for me write a nice code. My code NEVER looks like google git code. The most difficult thing is think a name that describes better a function/attribute/parameter/etc. Also make my code looks nice at first glance is a difficult task.
Heater wrote: Before trying to make it look nice I would make it at least work. That function returns a non-existent variable spellsDict.
Oopsy :oops:
kaksi wrote:It seems to me that line_number is not used.
It's after
scruss
Sun Jun 07, 2020 9:45 pm
Working or not, here's what autopep8 makes of it:
Args:
Returns:
    line_number = 0
            line_number += 1
                continue
                continue
            try:
                # Splited_uncommented_line[0] = spell Name
    return spellsDict
Python is not a language noted for its beauty, but in line with its "there can only be one way to do it" philosophy, autopep8 applies PEP 8. You can install it with sudo apt install python3-autopep8
Pronouns: he/him
Paeryn
Sun Jun 07, 2020 10:25 pm
It's after
The only line that uses line_number is, as you said, that single line that increments it. So whilst technically it is used because the increment operator uses it, it isn't used for anything and the function would produce the exact same result if you removed the variable and those two lines.
cmrincon
Mon Jun 08, 2020 8:30 am
Here is how my code looks after your tips:
Args:
Returns:
    line_number = 0
            line_number += 1
                continue
            fields =  [x.strip() for x in uncommented_line[0].split(',')]
            if len(fields) != 2:
                print("ERROR: incorrect line format. Line {} of file {}".format(line_number, config_file_path))
                continue
            try:
                spell_id = int(fields[1])
                spells_dictionary[spell_id] = fields[0]  #fields[0] is the spell name
                 continue
    return spells_dictionary
Now the code looks better!
I think that the function is too long and can be splitted in two diferent functions: read_config_file() and parse_line(), that will cause i would need to raise a few exceptions in parse_line, and catch them in read_config_file() in order to print the error and jump to the next line.
All the errors are not managed the same way, so i would need 3 different exceptions: ValueError, and 2 custom exceptions. The good thing is that ValueError and 1 of my custom exceptions would have the same except block. The bad thing is that all this exceptions will make my code more complex.
Will this make my code easier to read?
rpiMike
Mon Jun 08, 2020 8:50 am
Personally I don’t like underscores in variable names or function names:
config_file_path -> configFilePath
bensimmo
Mon Jun 08, 2020 9:12 am
The Python style guide is to use underscores for functions and variables, so they should work to that.
https://www.python.org/dev/peps/pep-000 ... able-names
jahboater
Mon Jun 08, 2020 9:32 am
Yes.
In English there are spaces between words, and capital letters are only used for proper nouns and the start of sentences.
The Python standard is the closer approximation.
Camel case might be slightly shorter, but readability comes first.
Mon Jun 08, 2020 11:30 am
I prefer camel case as well, just as readable in my opinion.
But the best code is the stuff that the person maintaining the code can read easily. I cannot read Linux kernel code easily, because the coding standard doesn't match how I think of code. Others have no problem.
Not easy!
Return to “Python”
