- Powering the Pi via stock usb-c
- Controlling a shift register (with the future intent of chaining multiple) to get the output signals for
- An 8-module 5V low-trigger relay which is powered separately to maintain isolation from the Pi.
- All of which to toggle 6 solenoid locks that require 12V at 600mA.
- Is it safe (for the Pi) for all powered systems to be derived from a single 12V source with one (or two) buck converters handling the 5V requirements?
- If I were to use this system, would it be safer (again, for the Pi) to have the 12V line split and use a single buck converter for each 5V component or to have a single buck converter and split the resulting 5V line between the two loads?
- Does the Pi even need to be isolated from the relay with these kinds of power demands?
- Given my own lack of electrical engineering knowledge, I feel I should ask if I'm missing a more obvious solution?
Edit: Re-organized the setup description and questions for better readability and clarity.
Edit2: I realize I'd accidentally double-posted without seeing the required moderator approval. Updated to reflect the better formatting of the second post since this one had traction. Sorry for the first-time forum faux pas.
Edit3: Changed the thread title to better reflect the question. Sorry for the excessive edits, and sorry if any of this is against the forum rules/etiquette.
