came across e very weird issue.
I mounted a CM3+ 8GB on a CMIO board using rpiboot on Ubuntu 18.04.
No I try to mount the same CM3+ using rpiboot on Ubuntu 20.04. But all I get is this:
May 29 10:51:19 dekitpc-24 kernel: [ 7506.304070] usb 1-1: new high-speed USB device number 33 using xhci_hcd
May 29 10:51:19 dekitpc-24 kernel: [ 7506.324469] usb 1-1: config index 0 descriptor too short (expected 55, got 32)
May 29 10:51:19 dekitpc-24 kernel: [ 7506.324698] usb 1-1: New USB device found, idVendor=0a5c, idProduct=2764, bcdDevice= 0.00
May 29 10:51:19 dekitpc-24 kernel: [ 7506.324702] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 29 10:51:19 dekitpc-24 kernel: [ 7506.324706] usb 1-1: Product: BCM2710 Boot
May 29 10:51:19 dekitpc-24 kernel: [ 7506.324710] usb 1-1: Manufacturer: Broadcom
May 29 10:51:19 dekitpc-24 mtp-probe: checking bus 1, device 33: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 29 10:51:19 dekitpc-24 mtp-probe: bus: 1, device: 33 was not an MTP device
May 29 10:51:22 dekitpc-24 kernel: [ 7509.484078] usb 1-1: USB disconnect, device number 33
May 29 10:51:22 dekitpc-24 kernel: [ 7509.792219] usb 1-1: new full-speed USB device number 34 using xhci_hcd
May 29 10:51:23 dekitpc-24 kernel: [ 7509.944601] usb 1-1: not running at top speed; connect to a high speed hub
May 29 10:51:23 dekitpc-24 kernel: [ 7509.945863] usb 1-1: New USB device found, idVendor=0a5c, idProduct=2764, bcdDevice= 0.00
May 29 10:51:23 dekitpc-24 kernel: [ 7509.945872] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=1
May 29 10:51:23 dekitpc-24 kernel: [ 7509.945877] usb 1-1: Product: BCM2710 Boot
May 29 10:51:23 dekitpc-24 kernel: [ 7509.945882] usb 1-1: Manufacturer: Broadcom
May 29 10:51:23 dekitpc-24 kernel: [ 7509.945886] usb 1-1: SerialNumber: Broadcom
May 29 10:51:23 dekitpc-24 mtp-probe: checking bus 1, device 34: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 29 10:51:23 dekitpc-24 mtp-probe: bus: 1, device: 34 was not an MTP device
May 29 10:51:24 dekitpc-24 kernel: [ 7511.798366] usb 1-1: USB disconnect, device number 34
Instead it works with another CM3+ which was bought some months ago. I get the same messages as reported above, but then it continues and mounts the CM3+ correclty:
May 29 10:46:42 dekitpc-24 kernel: [ 7229.824279] usb 1-1: new high-speed USB device number 30 using xhci_hcd
May 29 10:46:42 dekitpc-24 kernel: [ 7229.844549] usb 1-1: config index 0 descriptor too short (expected 55, got 32)
May 29 10:46:42 dekitpc-24 kernel: [ 7229.844773] usb 1-1: New USB device found, idVendor=0a5c, idProduct=2764, bcdDevice= 0.00
May 29 10:46:42 dekitpc-24 kernel: [ 7229.844778] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
May 29 10:46:42 dekitpc-24 kernel: [ 7229.844782] usb 1-1: Product: BCM2710 Boot
May 29 10:46:42 dekitpc-24 kernel: [ 7229.844785] usb 1-1: Manufacturer: Broadcom
May 29 10:46:42 dekitpc-24 mtp-probe: checking bus 1, device 30: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 29 10:46:42 dekitpc-24 mtp-probe: bus: 1, device: 30 was not an MTP device
May 29 10:46:43 dekitpc-24 mtp-probe: checking bus 1, device 30: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 29 10:46:43 dekitpc-24 mtp-probe: bus: 1, device: 30 was not an MTP device
May 29 10:46:46 dekitpc-24 kernel: [ 7232.998926] usb 1-1: USB disconnect, device number 30
May 29 10:46:46 dekitpc-24 kernel: [ 7233.308534] usb 1-1: new full-speed USB device number 31 using xhci_hcd
May 29 10:46:46 dekitpc-24 kernel: [ 7233.456816] usb 1-1: not running at top speed; connect to a high speed hub
May 29 10:46:46 dekitpc-24 kernel: [ 7233.457797] usb 1-1: New USB device found, idVendor=0a5c, idProduct=2764, bcdDevice= 0.00
May 29 10:46:46 dekitpc-24 kernel: [ 7233.457805] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=1
May 29 10:46:46 dekitpc-24 kernel: [ 7233.457810] usb 1-1: Product: BCM2710 Boot
May 29 10:46:46 dekitpc-24 kernel: [ 7233.457815] usb 1-1: Manufacturer: Broadcom
May 29 10:46:46 dekitpc-24 kernel: [ 7233.457819] usb 1-1: SerialNumber: Broadcom
May 29 10:46:46 dekitpc-24 mtp-probe: checking bus 1, device 31: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 29 10:46:46 dekitpc-24 mtp-probe: bus: 1, device: 31 was not an MTP device
May 29 10:46:48 dekitpc-24 kernel: [ 7235.314050] usb 1-1: USB disconnect, device number 31
May 29 10:46:48 dekitpc-24 kernel: [ 7235.832622] usb 1-1: new high-speed USB device number 32 using xhci_hcd
May 29 10:46:48 dekitpc-24 kernel: [ 7235.853339] usb 1-1: New USB device found, idVendor=0a5c, idProduct=0001, bcdDevice= 0.01
May 29 10:46:48 dekitpc-24 kernel: [ 7235.853348] usb 1-1: New USB device strings: Mfr=2, Product=1, SerialNumber=3
May 29 10:46:48 dekitpc-24 kernel: [ 7235.853353] usb 1-1: Product: Compute Module
May 29 10:46:48 dekitpc-24 kernel: [ 7235.853358] usb 1-1: Manufacturer: Raspberry Pi
May 29 10:46:48 dekitpc-24 kernel: [ 7235.853362] usb 1-1: SerialNumber: 3a906817
May 29 10:46:48 dekitpc-24 kernel: [ 7235.855196] usb-storage 1-1:1.0: USB Mass Storage device detected
May 29 10:46:48 dekitpc-24 kernel: [ 7235.855823] scsi host2: usb-storage 1-1:1.0
May 29 10:46:48 dekitpc-24 mtp-probe: checking bus 1, device 32: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 29 10:46:48 dekitpc-24 mtp-probe: bus: 1, device: 32 was not an MTP device
May 29 10:46:49 dekitpc-24 mtp-probe: checking bus 1, device 32: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1"
May 29 10:46:49 dekitpc-24 mtp-probe: bus: 1, device: 32 was not an MTP device
May 29 10:46:49 dekitpc-24 kernel: [ 7236.865337] scsi 2:0:0:0: Direct-Access RPi-MSD- 0001 PQ: 0 ANSI: 2
May 29 10:46:49 dekitpc-24 kernel: [ 7236.866153] sd 2:0:0:0: Attached scsi generic sg1 type 0
May 29 10:46:49 dekitpc-24 kernel: [ 7236.868534] sd 2:0:0:0: [sdb] 15269888 512-byte logical blocks: (7.82 GB/7.28 GiB)
May 29 10:46:49 dekitpc-24 kernel: [ 7236.868952] sd 2:0:0:0: [sdb] Write Protect is off
May 29 10:46:49 dekitpc-24 kernel: [ 7236.868959] sd 2:0:0:0: [sdb] Mode Sense: 0f 00 00 00
May 29 10:46:49 dekitpc-24 kernel: [ 7236.869170] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
May 29 10:46:50 dekitpc-24 kernel: [ 7236.891169] sdb: sdb1 sdb2
May 29 10:46:50 dekitpc-24 kernel: [ 7236.895804] sd 2:0:0:0: [sdb] Attached SCSI removable disk
Seems to be a bad combination of CM3+ batch and operating system.
