Now you can in Ubuntu 20.04 arm64 version
note the same command doesn't work on raspbian only ubuntu and ubuntu based distributions
sudo apt install obs-studioCode: Select all
sudo apt install obs-studiohackedmacbook111 wrote: ↑Tue May 26, 2020 8:17 pmEver wanted to livestream to Youtube or Twitch but couldn't on the raspberry pi 4 without buying extra equipment to be able to livestream
note the same command doesn't work on raspbian only ubuntu and ubuntu based distributionsrecomended if used with 2GB or 4GB modelsCode: Select all
Actually, I checked on their website, and they confirmed that you can just dohackedmacbook111 wrote: ↑Tue May 26, 2020 8:17 pmEver wanted to livestream to Youtube or Twitch but couldn't on the raspberry pi 4 without buying extra equipment to be able to livestream
