Mikebyrne000
Vintage Radio Speaker to 3.5mm audio jack??
Sun May 24, 2020 5:13 am
I’m looking to add my pi to a vintage radio I’ve just found.
In order to get audio to the existing speaker could I simply connect the red and black wires to an audio jack like the one in the link?
3.5mm Mono Screw Terminal Blocks for 1 ... YEb6VQ49BR
Re: Vintage Radio Speaker to 3.5mm audio jack??
Sun May 24, 2020 6:02 am
3.5mm Mono Screw Terminal Blocks for 12V Trigger Cable and IOT Relay, Ancable 2-Pack 1/8 Inch TS Male Plug to 2-PIN Screw Block Soldless Repair Adapter
No, the Pi can't drive a speaker directly. You'd need to add an amplifier between it and the speaker.
PS. Fixed your link.
Unreadable squiggle
Mikebyrne000
Sun May 24, 2020 6:49 am
Thanks for the help!
Could you point me in the right direction on the best one to get?
Sun May 24, 2020 7:42 am
For decent quality sound I take the line-level audio out from the Pi to my Sony surround system. (I don't actually like Sony equipment, I've had lots of bad experiences with it, but it was a gift).
For basic audio I use a cheap PAM8403 stereo amp module. I drive it from the same 5V supply as the Pi, which gives a small amount of hum when it is idle. It is only driving a small speaker for my doorbell, but it is adequate for that and we can hear it anywhere in the house. The module does require some soldering. Although it is stereo it won't be damaged if you only connect one speaker.
Others may advise better options.
Unreadable squiggle
