loquin
Trouble getting PostgreSQL installed on a Pi 4, 4GB
Sun May 24, 2020 3:44 am
Read this blog re installing PostgreSQL on a Raspberry Pi 4. It seemed straight-forward, so I started following along.
https://kb.objectrocket.com/postgresql/ ... ry-pi-part
When I ran the apt-get postgresql... I had several errors reported by the script, and no install.
~ $ sudo apt-get install postgresql postgresql-contrib
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  libllvm7 libpq5 postgresql-11 postgresql-client-11 postgresql-client-common
  postgresql-common ssl-cert sysstat
Suggested packages:
  postgresql-doc postgresql-doc-11 libjson-perl openssl-blacklist isag
The following NEW packages will be installed:
  libllvm7 postgresql postgresql-11 postgresql-client-11 postgresql-client-common
  postgresql-common postgresql-contrib ssl-cert sysstat
The following packages will be upgraded:
  libpq5
1 upgraded, 9 newly installed, 0 to remove and 407 not upgraded.
Need to get 24.6 MB/27.0 MB of archives.
After this operation, 105 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Err:1 http://mirror.os6.org/raspbian/raspbian buster/main armhf libllvm7 armhf 1:7.0.1-8+rpi3
  Connection failed [IP: 198.255.68.110 80]
Err:2 http://mirror.os6.org/raspbian/raspbian buster/main armhf postgresql-11 armhf 11.7-0+deb10u1
E: Failed to fetch http://mirror.os6.org/raspbian/raspbian/pool/main/l/llvm-toolchain-7/libllvm7_7.0.1-8+rpi3_armhf.deb  Connection failed [IP: 198.255.68.110 80]
E: Failed to fetch http://mirror.os6.org/raspbian/raspbian/pool/main/p/postgresql-11/postgresql-11_11.7-0+deb10u1_armhf.deb  Connection failed [IP: 198.255.68.110 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
[email protected]:~ $
As I'm still feelng my way around linux, I'm at something of a loss. I took a peek at the site the downloads were coming from (198.255.68.110,) and it appears that the paths in the install don't match the path at the site.
Any feedback would be greatly appreciated.
Lou
Re: Trouble getting PostgreSQL installed on a Pi 4, 4GB
Sun May 24, 2020 6:35 am
I suspect there was a temporary problem with that mirror site.
Try again later and it may work.
Unreadable squiggle
loquin
Mon May 25, 2020 6:22 am
I'll keep trying... However, this is now the fourth consecutive day that the install has failed.
Mon May 25, 2020 7:04 am
Ok, looks like there may be some issue with your networking then.
I just tried downloading one of those files from that server manually using wget and had no problem.
To check the connectivity could you try
ping -c 4 198.255.68.110
There are other tests to run, but we can skip a lot of them as you appear to have a working internet connection because your Pi resolved mirror.os6.org to 198.255.68.110 correctly.
Unreadable squiggle
