hawkeye6703
no global ipv4 address on my raspberry pi 4
Sun May 24, 2020 1:43 am
I can't find my public ipv4 address on my raspberry pi 4
Kendek
Re: no global ipv4 address on my raspberry pi 4
Sun May 24, 2020 8:10 am
wget -qO- v4.ifconfig.co
or
curl v4.ifconfig.co
thagrol
Sun May 24, 2020 12:22 pm
Your Pi doesn't have a public/global IP address (v4 or v6). Your router does. If you need access to your Pi from the global internet you'll need to setup port forwarding on it. There's a whole bunch of security issues to consider first though.
If you mean you can't find the IP v4 address the Pi is using on your private network, you have a number of options:
  • Plug in a monitor and keyboard, Run
    ifconfig -a
  • Check your router's admin pages. It should have a list of connected clients.
  • Use a network scanner
  • From another machine try
    ping raspberrypi.local
    The output shouldcontain the IP address. Replace "raspberrypi" with the hostname of the pi in question if you've changed it.
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
