lavurso
RPi_Cam_Web_Interface issue
Sun May 24, 2020 1:31 am
I have a Raspberry Pi 3 Model B Rev 1.2 with a Raspberry Pi Camera V2. Fresh install of Buster on my microSD card. Only thing I've changed is the desktop background. My aim is to use RPi_Cam_Web_Interface for astrophotography.
I enabled the camera in preferences and ran install.sh.
[email protected]:~/RPi_Cam_Web_Interface $ sh install.sh
+ readlink -f install.sh
+ dirname /home/pi/RPi_Cam_Web_Interface/install.sh
+ cd /home/pi/RPi_Cam_Web_Interface
+ dpkg-query -W -f=${Status} dialog
+ grep -c ok installed
+ [ 1 -eq 0 ]
+ color_red=tput setaf 1
+ color_green=tput setaf 2
+ color_reset=tput sgr0
+ versionfile=./www/config.php
+ cat ./www/config.php
+ grep 'APP_VERSION'
+ cut -d ' -f4
+ version=v6.6.9
+ backtitle=Copyright (c) 2015, Bob Tidey. RPi Cam v6.6.9
+ jpglink=no
+ phpversion=7.3
+ [ ! -e ./config.txt ]
+ source ./config.txt
install.sh: 72: install.sh: source: not found
+ rpicamdirold=
install.sh: 74: install.sh: Bad substitution
I'm not very technical and know very little programming. The lines from the install script cited from the traceback are:
source ./config.txt
rpicamdirold=$rpicamdir
if [ ! "${rpicamdirold:0:1}" == "" ]; then
rpicamdirold=/$rpicamdirold
fi
I don't know what I can do so this installs and functions.
Thank you.
P.S. This is the config file
#This is config file for main installer. Put any extra options in here.
rpicamdir="html"
webserver="apache"
webport="80"
user=""
webpasswd=""
autostart="yes"
jpglink="no"
phpversion="7.3"
lavurso
Re: RPi_Cam_Web_Interface issue
Mon May 25, 2020 2:15 pm
Bump
trejan
Mon May 25, 2020 2:51 pm
Don't use sh with this. install.sh was written for bash but you're forcing it to use sh which is very basic. Do ./install.sh instead.
