wardx
show pictures on restart and shutdown screens
Sun May 24, 2020 1:26 am
Hello there,
I want to show users specific images when restarting and shutting down the Raspbian operating system. I prepared some services with the resources I found on the internet regarding these transactions. Despite the fact that the services were working, I could not see the pictures on the screen during the restart and shutdown processes. But when I said create any file, I saw that it occurred. I wonder where is the wrong place? I would be glad if you could help.
Shutdown Service
[Unit]
Description=show image on starting shutdown
DefaultDependencies=no
Before=shutdown.target
[Service]
#ExecStart=/usr/bin/python3 /home/pi/payclient/os_custom_data/framebuffer-pythonscript.py -img /home/pi/os_custom_data/powerdownimage.jpg
ExecStop=/usr/bin/python3 /home/pi/payclient/os_custom_data/framebuffer-pythonscript.py -img /home/pi/os_custom_data/powerdownimage.jpg
Type=oneshot
[Install]
WantedBy=multi-user.target
Reboot Service
[Unit]
Description=show image on reboot
Before=reboot.target
[Service]
Type=oneshot
ExecStart=/usr/bin/python3 /home/pi/payclient/os_custom_data/framebuffer-pythonscript.py -img /home/pi/os_custom_data/reboot.jpg
ExecStart=touch /home/pi/reboot2.txt
[Install]
#WantedBy=reboot.target
WantedBy=graphical.target
Unplug Service
[Unit]
Description=safe-to-power-off image
After=umount.target
Before=final.target
[Service]
ExecStart=/usr/bin/python3 /home/pi/payclient/os_custom_data/framebuffer-pythonscript.py -img /home/pi/os_custom_data/unplugimage.jpg
Type=oneshot
[Install]
WantedBy=shutdown.target
DarkElvenAngel
Re: show pictures on restart and shutdown screens
Sun May 24, 2020 4:06 am
Your close.
These are my services I use. Do you have the logging switch to a different terminal otherwise the images will be overwritten very quickly. (That's taken care of during boot if you have a boot splash I assume you have done that.) Python is slow to load and these screens are only viewable for a few seconds if at all. I use mine on a Pi Zero, and I use a C program to show images. Another method is if the screen will always be the same resolution is to just copy the raw image to the framebuffer.
Reboot target
[Unit]
Description=show reboot image
Before=halt.target
[Service]
ExecStart=/bin/fbsplash /etc/splash/reboot.png
Type=oneshot
[Install]
WantedBy=halt.target reboot.target
Shutdown target
[Unit]
Description=show image shutdown (poweroff command)
Before=halt.target
[Service]
ExecStart=/bin/fbsplash /etc/splash/shutdown.png
Type=oneshot
[Install]
WantedBy=halt.target poweroff.target
Unplug target
[Unit]
Description=Show unplug image (full power off)
After=umount.target
Before=final.target
[Service]
ExecStart=/bin/fbsplash /etc/splash/unplug.png
Type=oneshot
[Install]
There's also fbv it's not available in the raspbian repository but you can build it from a GitHub repo.
Try editing the services and see if it works for you. If not I'll dig up some links for you if you need them.
wardx
Sun May 24, 2020 9:37 pm
Thank you for your answer, but my problems continue.
unfortunately i couldn't install fbsplash. so I couldn't try the commands you wrote. Just like there should be a more practical way to add images to the restart and shutdown screens. I tried to show it with an app like fbi instead of fpsplash, but the result is unsuccessful. I will be very happy if you help me.
DarkElvenAngel
Sun May 24, 2020 10:35 pm
So I think you got the idea from this link
https://www.madebymany.com/stories/fun- ... spberry-pi
I have used their method the services I tweaked a bit to get slightly better results. If you're doing this on a fast RPI it might be too quick. I never got the unplug image to show because the system turns off the display. It's also an old tutorial my pi is running Stretch I will transfer the services to my pi 4 and let you know if I have success.
Hmm can you post your cmdline.txt.
Fbsplash is a program I wrote but this
should work https://github.com/dimkr/fbim
What type of RPI are you trying this on?
wardx
Sun May 24, 2020 11:01 pm
Yes, I saw that page while doing research on this subject. I bought it from Python for example, but when I couldn't get the result I wanted, I looked for other solutions.
I probably cannot see images on the screen due to the fast shutdown, but can such a situation be for reboot?
I test with Raspberry pi 3 model B + and Raspberry pi 4 model B.
I use Raspberry Pi Official Touch Screen. I use the latest version of Raspbian Buster as the operating system.
How can I perform these operations with fbim. Or should I give up this search for a solution?
cmdline.txt
console=serial0,115200 console=tty1 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo
DarkElvenAngel
Sun May 24, 2020 11:26 pm
cmdline.txt
Change your cmdline.txt to
console=serial0,115200 console=tty2 root=PARTUUID=ea7d04d6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo silent quiet loglevel=0 splash
That will make your boot up dark unless you have some sort of boot splash setup. But it might help on shutdown.
Do you know how to use git and make?
I would not give up. Try that and see what
DarkElvenAngel
Sun May 24, 2020 11:40 pm
Just incase you don't now how it works.
[~]$ sudo apt install make git build-essential
[~]$ git clone https://github.com/dimkr/fbim.git
[~]$ cd fbim
[~/fbim]$ make
[~/fbim]$ sudo make install
Then you can set your scripts to run /bin/fbim (image file)
wardx
Mon May 25, 2020 12:04 am
The reason for asking the installation was that I had an addiction problem in the previous project, now my system is running in the system. Your answer will definitely be useful for other users.
I updated the cmdline.txt file as you sent it. I restarted and shut down the system, but the result was black. The system showed the raspian splash screen for about 1 ~ 2 seconds at first boot, then waited on the black screen until x started. Thank you for your help.
DarkElvenAngel
Mon May 25, 2020 12:23 am
Your welcome, is this current setup suitable for your needs?
I will look into the shutdown splashes tomorrow and test with the official touchscreen. I have a Pi 3B+ setup
wardx
Mon May 25, 2020 12:36 am
seems to be appropriate at the moment. I hope I will make progress with your help in this regard. I will be waiting for your reply with excitement.
DarkElvenAngel
Mon May 25, 2020 5:06 pm
Bad news,
I have set everything up and gone through the some tests and troubleshooting.
[*] rpi-display-backlight.service as soon as you start either shutdown or reboot it turns off the display
[*] poweroff.target is disabled by default in Buster
[*] reboot.target is disabled by default in Buster
These are the services as I tried them
Reboot target Doesn't work
[Unit]
Before=halt.target
[Service]
Type=oneshot
[Install]
Shutdown target Doesn't work
[Unit]
Before=halt.target
[Service]
Type=oneshot
[Install]
Unplug target Works*
[Unit]
After=umount.target
Before=final.target
[Service]
Type=oneshot
[Install]
* only if you disable the rpi-display-backlight.service and then the display goes random because the input signal is lost.
Here are somethings I tried
$ systemctl list-unit-files --type=target
UNIT FILE                     STATE
basic.target                  static
bluetooth.target              static
boot-complete.target          static
cryptsetup-pre.target         static
cryptsetup.target             static
ctrl-alt-del.target           disabled
default.target                indirect
emergency.target              static
exit.target                   disabled
final.target                  static
getty-pre.target              static
getty.target                  static
graphical.target              indirect
halt.target                   disabled
hibernate.target              static
hybrid-sleep.target           static
initrd-fs.target              static
initrd-root-device.target     static
initrd-root-fs.target         static
initrd-switch-root.target     static
initrd.target                 static
kexec.target                  disabled
local-fs-pre.target           static
local-fs.target               static
multi-user.target             static
network-online.target         static
network-pre.target            static
network.target                static
nfs-client.target             enabled
nss-lookup.target             static
nss-user-lookup.target        static
paths.target                  static
poweroff.target               disabled
printer.target                static
reboot.target                 disabled
remote-cryptsetup.target      disabled
remote-fs-pre.target          static
remote-fs.target              enabled
rescue-ssh.target             static
rescue.target                 static
rpcbind.target                static
runlevel0.target              disabled
runlevel1.target              static
runlevel2.target              static
runlevel3.target              static
runlevel4.target              static
runlevel5.target              indirect
runlevel6.target              disabled
shutdown.target               static
sigpwr.target                 static
sleep.target                  static
slices.target                 static
smartcard.target              static
sockets.target                static
sound.target                  static
suspend-then-hibernate.target static
suspend.target                static
swap.target                   static
sysinit.target                static
system-update-pre.target      static
system-update.target          static
time-sync.target              static
timers.target                 static
umount.target                 static
64 unit files listed.
I tried to enable the two targets this doesn't work, my guess is that they don't get triggered.
I tried this with HDMI and it doesn't work.
It seems to work on a Pi Zero running Stretch.
Just to add salt to it all I ran systemctl list-unit-files --type=target on Stretch to see and now it's very confusing!
UNIT FILE                 STATE
basic.target              static
busnames.target           static
default.target            static
final.target              static
getty.target              static
graphical.target          static
paths.target              static
rescue.target             disabled
runlevel1.target          disabled
runlevel5.target          static
sleep.target              static
sound.target              static
swap.target               static
59 unit files listed.
I don't want to give up but I've done all I can think of. If someone with a better grasp of systemd can help us out here that's what we need.
Sorry it's not better news for you hopefully some else can pick this up and we can figure it out.
wardx
Mon May 25, 2020 9:10 pm
Thank you very much. I looked at it too, but things are getting clogged. I will continue researching on systemd. I hope I can find a solution, if I find I will write it here. Thanks again for your efforts.
DarkElvenAngel
Mon May 25, 2020 10:41 pm
Your welcome, please do keep this up to date it might help others as well.
This seems to be one of those things that broke with Buster or it could be user error.
From what I tried and could see, it would be a good place to start looking at the shutdown/restart order of targets. On my Pi zero with Stretch I call a script not just putting up the image. The script I use on my system is to complex to post here and wouldn't be of any use really.
Good luck, if I find anything I will update here as well.
DarkElvenAngel
Thu May 28, 2020 12:03 am
Update,
I haven't had much luck sorting out the order systemd uses during shutdown, I asked in this thread for help.
What I did figure out is something during shutdown clears the terminal! I saw my splash image pop up ever so briefly. So I went to my original thought that my old approach was introducing enough delay to make the image come up.
This is my service I tested with
[Unit]
Before=umount.target
[Service]
ExecStart=/home/pi/splash
Type=oneshot
[Install]
WantedBy=shutdown.target reboot.target halt.target kexec.target
now the splash script is as follows
#!/bin/bash
# turn off cursor
echo -e "\e[?25l" > /dev/tty1
# very important sleep maybe less time is ok?
sleep 1
# display the splash image
/home/pi/Projects/fbim/fbsplash /home/pi/Splash/shutdown.jpg
# this sleep is not needed
# sleep 2
# mount usbkey and capture the closing system logs for systemd
mount /dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.3:1.0-scsi-0:0:0:0-part1 /mnt
#systemd-analyze plot > /mnt/systemd.svg
journalctl | grep systemd > /mnt/system.log
sync
umount /mnt
exit 0
I haven't done full tests yet with each type of shutdown but I thought this progress update would be helpful.
This was tested on a PI4 B 4GB with HDMI screen attached I will test on a PI3 B+ with the official touch screen tomorrow.
DarkElvenAngel
Thu May 28, 2020 9:19 pm
Update,
I now get my shutdown restart and unplug images.
This is working on the most up to date Raspberry Pi OS
My final services are as follows
splash-shutdown.service
[Unit]
Description=show shutdown image
[Service]
ExecStart=/home/pi/splash /home/pi/Splash/Pi4B-poweroff.jpg
Type=oneshot
[Install]
WantedBy=halt.target shutdown.target
splash-reboot.service
[Unit]
[Service]
ExecStart=/home/pi/splash /home/pi/Splash/Pi4B-rebooting.jpg
Type=oneshot
[Install]
splash-unplug.service
[Unit]
After=umount.target
Before=final.target
[Service]
ExecStart=/home/pi/splash /home/pi/Splash/Pi4B-unplug.jpg
Type=oneshot
[Install]
splash script
#!/bin/bash
sleep .5
echo 'q' | fbv -cike "$1"
exit 0
fbv is not in the RaspberryPi OS repos so you have to get it from github.
The rpi-display-backlight.service will conflict with these and it must be modified the problem is the display will turn off just after the system starts to reboot or restart.
Here is the service as seen from github
[Unit]
Description=Turns off Raspberry Pi display backlight on shutdown/reboot
ConditionPathIsDirectory=/proc/device-tree/rpi_backlight
[Service]
Type=oneshot
ExecStart=/bin/sh -c '/bin/echo 1 > /sys/class/backlight/rpi_backlight/bl_power'
[Install]
WantedBy=reboot.target halt.target poweroff.target
disabling this service is one way to do things but then the display will remain on until you remove power. changing the script would be the next best thing.
#!/bin/bash
sleep .5
if [ -n $2 ] && [ -d /sys/class/backlight/rpi_backlight ] ; then
  sleep 2
exit 0
and just change the splash-unplug.service line to
ExecStart=/home/pi/splash /home/pi/Splash/Pi4B-unplug.jpg off
This should display the unplug image for two seconds and then turn the screen off.
OR change the splash-unplug.service to
[Unit]
Description= Turn of RPI Display but show no image
After=umount.target
Before=final.target
[Service]
Type=oneshot
[Install]
That's all I have for this update, hope it helps.
ToxicTrev
Fri May 29, 2020 12:01 pm
hey guys, I have been working on a custom jukebox using the fruitbox software, which I realise is a differet topic, but my question here is I want to put in a custom loading / splash screen for the raspberry pi. I was doing some research and it looks like the directory to the splash image is in the usr/plymoth/themes/pix or something along those lines, which the version of the fruitbox image disk doesnt seem to have that file.
how would I go about putting in a custom splash / loading screen for this ?
DarkElvenAngel
Fri May 29, 2020 2:38 pm
No problem please post in this thread as this thread deals with shutdown splashes.
page five is the best place to start.
Return to “Raspberry Pi OS”
