CCoen
Error: raspberry pi dpkg was interrupted, you must manually run sudo dpkg --configure a to correct this problem
Sat May 23, 2020 9:00 pm
Hello, I just got my raspberry pi 4 4gb and when I got raspbian installed but when I try to use any command such as sudo apt-get (name) I get the error raspberry pi dpkg was interrupted, you must manually run sudo dpkg --configure a to correct this problem. Iv tried running the sudo dpkg --configure a, but that just gives me the same message as before. Iv also tried sudo apt-get install -f and I get the same message.
Do I have to do something before trying to install anything, all iv done is getting raspbian installed and setup wifi and such.
