calindbl
Wifi does not connect PI4
Sat May 23, 2020 2:45 am
My pi 4 will not connect to my home wifi, but it will connect to my Iphone hotspot. I've checked the wpa_supplicant.conf file and it seems OK. The router is brand new and all my other devices have connected fine. Anyone have any ideas?
pcmanbob
Re: Wifi does not connect PI4
Sat May 23, 2020 11:56 am
You have provided so little information its impossible to say what the problem might be.
so
what OS is you pi running
does your router support both 2.4Ghz and 5Ghz , if so are they using different ssid's
does you pi see the ssid of your router
do you have any strange characters in the ssid you are trying to connect to.
