aujat
Unable to enable wifi interface "wlan0" in RaspberryPi 4 B [ARCH Linux]
Sat May 23, 2020 4:51 am
I have a RaspberryPi 4 B which runs Arch Linux for ARM.
I follow the installation steps provided by https://archlinuxarm.org/platforms/armv ... berry-pi-4, It can boot successfully.
However, when I type `ip addr show`, it print out the following links for wlan0:
wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> ................. DOWN ........
While, the Ethernet interface is UP.
No matter how I enter `ip link set wlan0 up`, the status of wlan0 is still DOWN.
I login to this Raspberry through ssh via Ethernet interface.
How can I turn wlan0 up?
GizmoTheGreen
Re: Unable to enable wifi interface "wlan0" in RaspberryPi 4 B [ARCH Linux]
Sat May 23, 2020 8:08 pm
I think easiest way is install netctl and dialog (will give you access to wifi-menu command) for easy wifi setup.
else you will have to use wpa_supplicant, you can find instructions on usage on arch wiki :)
I got an error trying to pass wpa_passphrase in command so I piped it to a txt file then used that in wpa_supplicant command instead (after -c put the filename)
Return to “Arch”
