hackedmacbook111
Contact: YouTube
Minecraft 1.15.2 not running smoothly
Sat May 23, 2020 1:25 am
I just installed Minecraft 1.15.2 on a Raspberry Pi 4B 4GB
When ever I connect to a server example wiimmfi.minehut.gg
The game crashes when I try to connect to it
The server has viaversion and via backwards plugins to allow 1.9+ to join
I tryed 1.12.2 but it just freezes the raspberry pi's mouse
Is there anyway to fix this
hackedmacbook111
Contact: YouTube
Re: Minecraft 1.15.2 not running smoothly
Sat May 23, 2020 1:31 am
It doesn't matter what server I join it crashes in 1.12.2 on the raspberry pi they run fine
all servers tested have both 1.12.2 and 1.15.2 support
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 1:46 am
I created a game in single player in default screen size and fullscreen
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 1:54 am
When trying to load a server Minecraft came up with this notice
Minecraft has run out of memory
This could be caused by a bug in the game or by the
Java Virtual Machine not being allocated enough
memory.
To prevent level corruption, the current game has quit.
We've tried to free up enough memory to let you go back to
the main menu and back to playing, but this may not have worked.
Please restart the game if you see this message again
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 2:41 am
Here is a video of connecting to the server then the game freezes computer causing me to have to use a terminal to reboot
watch evidence at
https://youtu.be/CcFh_RIlDIs
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 3:02 am
Can someone post with more than 50 views I expected someone to post an idea I could try
If anyone knows what this is could they please help
Cob
Sat May 23, 2020 9:29 am
It’s a software issue so try the correct section - viewforum.php?f=66
Also you posted at 2.30am UK time. The forum will be a little quieter at that time.
Sat May 23, 2020 9:45 am
Please be patient, it is Saturday morning in the UK, also have you searched for similar post while you wait ? such as:
viewtopic.php?t=270973
Though you already posted here:
viewtopic.php?f=78&t=274756&p=1665265#p1664972
This Forum is run on a totally voluntary basis, so your urgency may not be actually be seen as urgent to other people.
rpiMike
Sat May 23, 2020 10:02 am
Are you trying to run Minecraft through VNC or directly on the Pi ?
Do not run anything else at the same time as Minecraft.
You might get more help if you posted in the 1.15.2 tutorial thread.
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 1:51 pm
I am running only minecraft and the terminal
The reason I am upgrading to 1.15.2 from 1.12.2
I already have 1.12.2 running smooth almost never crashes
When in single player it runs okay but I am not here for single player because I can play it on my pc
but I can't play multiplayer on my pc because I don't have internet going to it
That is why I use raspberry pi 4
I used this tutorial to install this viewtopic.php?t=270973
The server I am trying to connect
I have set render distance to 3
should I try it on true raspbian buster
I am currently using raspbian X nighthawk edition which is raspbian but with xfce desktop instead
The server loaded then I try to move then the game crashes
Raspbian X nighthawk edition is raspbian buster
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 1:53 pm
I am running it dirrectly on the raspberry pi 4 B 4GB
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 1:58 pm
Can someone please tell me what this mesns
Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
This is the error before minecraft 1.15.2 crashed
rpiMike
Sat May 23, 2020 2:35 pm
Try it on the official Raspbian Buster fully updated.
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 7:05 pm
Would it run better on Raspbian Buster Lite
rpiMike
Sat May 23, 2020 7:09 pm
Probably won’t run at all due to graphics drivers.
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 7:20 pm
Do I just install it on raspbian buster full or should I use noobs instead
Sat May 23, 2020 8:18 pm
NoobS is not an Operating System :?
https://www.raspberrypi.org/downloads/
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 9:32 pm
I downloaded and flashed raspbian buster to 16GB PNY micro sd card on raspberry pi 4 B 4GB
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 9:34 pm
Can I copy over files without having to do installation process again or do I have to wait another 24 minutes for a new alt to come in
rpiMike
Sat May 23, 2020 9:58 pm
What’s a ‘new alt’ ?
Update Raspbian.
sudo apt update
sudo apt full-upgrade
Then do a full install of Minecraft according to the tutorial.
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 10:45 pm
An alt is a new account that are givin out on websites for free
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 11:39 pm
I started the installation process of 1.15.2 without changeing to gldrivers is it OK to continue installing minecraft 1.15.2 I just installed 1.15.2 from launcher and it came up with error code should I continue and turn on gl driver later
hackedmacbook111
Contact: YouTube
Sun May 24, 2020 2:22 am
I successfully installed minecraft 1.15.2 it plays servers
but it freezes every few minutes for a few seconds otherwise its playable in multiplayer on servers
is there a way to increase performance server and player boh have render chunks set to 3
is there any more way to make it run smoother on raspberry pi 4 B 4GB
Return to “Gaming”
