darkskyseeker
C or CS mount to M42
Sat May 23, 2020 12:35 am
I am hoping to use my Pi High Quality camera with my telescope. The scope interfaces with M42 threads. Is there a threaded adapter with male threads for the camera mount transitioning to female M42?
To be, or not to be! Those are 2 questions.
W. H. Heydt
Re: C or CS mount to M42
Sat May 23, 2020 12:51 am
Google is broken today?
https://www.google.com/search?client=fi ... 42+adapter
darkskyseeker
Sat May 23, 2020 1:30 am
I have been Googling and can't find it. That is why I asked here.
W. H. Heydt
Sat May 23, 2020 2:56 am
I don't know what to say... The first search I used got the results for which I posted the link. And my Google-fu is pretty poor. If I had to find a lens adapter I could probably do it without Google just by looking on one of the major NYC photo suppliers, like B&H.
markkuk
Sat May 23, 2020 7:35 am
Are you sure it's really a M42 mount instead of a T-mount? Both are 42mm in diameter but the thread pitch is different. T-mount is commonly used in telescope and microscope attachments.
xkubazz
Sat May 23, 2020 11:36 am
https://fotodioxpro.com/collections/c-m ... /m42-c-pro
https://www.srb-photographic.co.uk/c-mo ... 0588-p.asp
I have SRB one, works good.
But as noted above, check if your telescope is M42 or T-mount, they have the same diameter but different pitch angles and are often confused. Most telescopes actually use T-mount. Here is example of T to C adapter: https://www.astroshop.eu/extension-ring ... le/p,22010
Those should be available in every astronomy shop.
darkskyseeker
Sat May 23, 2020 4:14 pm
Thank you for the examples and help. Most of my search results yielded the wrong gender(s). I am using a t-adapter. I ordered a part. I was too slow on the uptake to get my order in for the high quality camera on the announcement day and am still waiting. It will be a race between the camera and the adapter.
RoboRob
Contact: Website Skype
Sun May 24, 2020 9:10 am
This is an adapter for T2 thread used in the telescope area (which is 42 mm but with 0.75 mm thread pitch, instead of M42 with 1 mm thread pitch): https://www.astromarket.org/andere-adap ... r_0_select
darkskyseeker
Wed May 27, 2020 8:06 pm
I ordered the part from Astroshop (Germany) Saturday morning, and it just arrived.
Return to “Camera board”
