vidrazor
New Pi 4 Camera Ribbon
Fri May 22, 2020 2:40 am
Hi folks, I'm rigging up a Pi4/Pi Camera duo to use in astrophotography, and I'm planning on bolting the camera right to the top of the Pi 4 case and using it as a guide cam in addition to other astro duties in one contained package.
So my question is really about the connecting ribbon from the camera to the Pi 4. Is it possible to cut a short piece of it and still use it? If not, where could I order a shorter ribbon with the same connections? I'm only going to need about 3-4 inches max within the case.
Thanks for any info on this.
wildfire
Re: New Pi 4 Camera Ribbon
Fri May 22, 2020 4:31 pm
Google is your friend...
https://www.amazon.com/Flex-Cable-Raspb ... B00I6LH2GA (10cm so around 4 inches).
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
W. H. Heydt
Fri May 22, 2020 4:34 pm
No. As above, cables in various lengths are readily available commercially. When you examine a cable, you should be able to see why just cutting it to a convenient length won't work.
vidrazor
Sun May 24, 2020 1:21 am
OK guys thanks for the info. I'm raw to all this, so I wasn't sure how pliable the tech is.
Thanks again.
Return to “Beginners”
