busywait
Buster/Debian vi/vim cursor key misconfiguration and workaround
Thu May 21, 2020 2:35 pm
Using the insert mode in vi, when I try to navigate text using the cursor (arrow) keys my cursor jumps down a line and unwanted characters (A, B, C, D) are entered into my text. Similar problems using the Home/End keys.
This happens in the default desktop xterm (keyboard and monitor plugged directly into my Pi 4), or over SSH. This doesn't happen logged in to the TTY1-6 Consoles that I see when I press Ctrl+Alt+F1-6.
Steps to reproduce:
- fresh Rapsbian Buster full image install with the vim-tiny package, no other vim packages, configure with GB or UK locales
- boot to desktop
- start LXPanel (default terminal icon on the top panel), or ssh to login to the Pi
- from the command line, type vi
- in vi, type i (to enter insert mode)
- type a few carriage returns
- hit the up arrow
Expected behaviour
- cursor moves up
Observed behaviour
- The letter A appears
Workaround
- Option 1: Copy the example vimrc in to your home directory, and restart vi
cp /etc/vim/vimrc ~/.vimrc
- Option 2: Install a more complete version of vim, eg
sudo apt install vim
The version of vi that I am using is /usr/bin/vim.tiny from the default vim-tiny package, and there are no other vim packages installed when I see this problem. If I do install the full vim package alongside vim-tiny then the "vim.tiny" binary starts to work correctly too.
[email protected]:~ $ dpkg -S $(realpath $(which vi))
vim-tiny: /usr/bin/vim.tiny
Related info that I don't think quite describes what's happening:
https://unix.stackexchange.com/question ... -vim-vimrc
(I can't find any default.vim file in Raspian Buster when I only have vim.tiny installed)
Is it helpful and possible for me to create an Issue for this sort of thing somewhere?
kerry_s
Re: Buster/Debian vi/vim cursor key misconfiguration and workaround
Thu May 21, 2020 5:12 pm
who navigates in insert mode? :roll:
bls
Contact: Twitter
Thu May 21, 2020 5:22 pm
Just tried this on an xterm connected to a Pi4, with Buster 2020-02-13 Lite and the same version of vim as you, and did not see the behavior you're reporting. Possibly a termcap issue? What are the contents of your /etc/default/keyboard?
busywait
Thu May 21, 2020 6:31 pm
[email protected]:~ $ cat /etc/default/keyboard
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="gb"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
bls
Contact: Twitter
Thu May 21, 2020 6:45 pm
XKBMODEL="pc105"
XKBLAYOUT="gb"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
Still works correctly for me. Please post the output of
echo $TERM
stty -a
busywait
Thu May 21, 2020 6:54 pm
echo $TERM
stty -a
I only see the problem when there is no .vimrc file in my home directory (there was not one by default in my clean Buster full install). Have you renamed yours if you have a .vimrc?
Here's the output through ssh...
[email protected]:~ $ echo $TERM
xterm-256color
[email protected]:~ $ stty -a
speed 38400 baud; rows 30; columns 120; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = M-^?; eol2 = M-^?; swtch = <undef>; start = ^Q; stop = ^S;
susp = ^Z; rprnt = ^R; werase = ^W; lnext = ^V; discard = ^O; min = 1; time = 0;
-parenb -parodd -cmspar cs8 -hupcl -cstopb cread -clocal -crtscts
-ignbrk -brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr icrnl ixon -ixoff -iuclc ixany imaxbel iutf8
opost -olcuc -ocrnl onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
isig icanon iexten echo echoe echok -echonl -noflsh -xcase -tostop -echoprt echoctl echoke -flusho -extproc
busywait
Thu May 21, 2020 7:08 pm
Interesting - if I log directly into the console, then there is no problem in vi even without .vimrc:
 $ echo $TERM
linux
$ stty -a
speed 38400 baud; rows 67; columns 240; line = 0;
intr = ^C; quit = ^\; erase = ^?; kill = ^U; eof = ^D; eol = <undef>;
eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S; susp = ^Z; rprnt = ^R;
-parenb -parodd -cmspar cs8 hupcl -cstopb cread -clocal -crtscts
-ignbrk brkint -ignpar -parmrk -inpck -istrip -inlcr -igncr icrnl ixon -ixoff
-iuclc -ixany imaxbel iutf8
stty -a
If I start the Rasberry Pi Desktop and start the default terminal then there is a problem in vi.
xterm-256color
speed 38400 baud; rows 24; columns 80; line = 0;
-iuclc -ixany -imaxbel iutf8
And, the problem goes away everywhere if I create myself a .vimrc.
bls
Contact: Twitter
Thu May 21, 2020 7:15 pm
xterm-256color
What is the terminal device that you're using that you ssh from? I'm using a standard xterm, and my TERM shows up just like yours (xterm-256color).
The only differences between your stty -a output and mine are i have -ixany and -imaxbel, but those dont' seem to be relevant, based on the descriptions in 'man stty'.
Not sure what to explore or suggest next.
Oh, and back to your original question, the system-wide vimrc default is at /etc/vim/vimrc. It's also at /usr/share/vim/vimrc, which is a symlink to the one in /etc/vim/vimrc.
bls
Contact: Twitter
xterm-256color
Yes, no .vimrc file in my home directory.
busywait
Thu May 21, 2020 7:31 pm
Well, thanks for looking. Very strange it doesn't hit you, but perhaps there's some other locale related variation?
I can't believe it would just be me that sees this. It happens right in the default Raspberry Pi x-term, and also from the ssh command line client in Ubuntu for Windows, and PuTTY for Windows.
I've found that it is not a problem in the default TTY console.
My problem goes away everywhere when I copy /etc/vim/vimrc in to my own home directory as ".vimrc". So, it seemed to me like this was an oversight in the default install.
kerry_s
Thu May 21, 2020 7:36 pm
there is no problem, this is user error.
your not suppose to navigate in "insert" mode, you edit/change/replace whatever & press "esc" then move/navigate.
you should use "vimtutor" to learn the basics.
PeterO
Thu May 21, 2020 7:37 pm
ISTR vi is installed by default. You have to install vim yourself.
PeterO
busywait
Thu May 21, 2020 9:12 pm
PeterO
I type vi to run the editor, but it runs vim; if I ask apt, there is no vi package, but there is a vim package:
[email protected]:~ $ vi --version
VIM - Vi IMproved 8.1 (2018 May 18, compiled Jun 15 2019 16:41:15)
Included patches: 1-875, 878, 884, 948, 1046, 1365-1368, 1382, 1401
Modified by [email protected]
Compiled by [email protected]
Small version without GUI.  Features included (+) or not (-):
[email protected]:~ $ apt info vi
N: Unable to locate package vi
E: No packages found
kerry_s
Thu May 21, 2020 9:23 pm
most linux only use the "vim-tiny" as nano is the default, considered more user friendly.
show vim-tiny
Package: vim-tiny
Version: 2:8.1.0875-5
Priority: important
Section: editors
Source: vim
Maintainer: Debian Vim Maintainers <[email protected]>
Installed-Size: 1,098 kB
Provides: editor
Depends: vim-common (= 2:8.1.0875-5), libacl1 (>= 2.2.23), libc6 (>= 2.28), libselinux1 (>= 1.32), libtinfo6 (>= 6)
Suggests: indent
Homepage: https://www.vim.org/
Download-Size: 503 kB
APT-Manual-Installed: yes
APT-Sources: http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
Description: Vi IMproved - enhanced vi editor - compact version
 Vim is an almost compatible version of the UNIX editor Vi.
 This package contains a minimal version of Vim compiled with no GUI and
 a small subset of features. This package's sole purpose is to provide
 the vi binary for base installations.
 If a vim binary is wanted, try one of the following more featureful
 packages: vim, vim-nox, vim-athena, vim-gtk, or vim-gtk3.
Thu May 21, 2020 9:30 pm
First thing I do on any new Raspbian install is sudo apt install vim-full to make it work normally.
I'll do your homework for you for a suitable fee.
Paeryn
Thu May 21, 2020 9:35 pm
PeterO
The default is vim-tiny which is basically vim compiled to only work in vi-compatible mode and without all the useful things vim has. Also the full vim will default to vi-compatible mode if there isn't a .vimrc (or .vim/vimrc). I've never understood why distros use vim-tiny (apart from severely space restricted ones).
It's not user error, who says you aren't supposed to navigate in insert mode? The arrow keys, page up/down, home and end have always worked in insert mode (or have done for the last 25+ years I've been using vi & vim).
If you're getting the letters A, B, C or D when pressing a cursor key then it sounds like the escape-codes for the keys aren't being parsed correctly (up is Esc[A / EscOA etc.), we used to get that intermittently on terminals that had a very dodgy and slow connection to the workstations.
She who travels light — forgot something.
busywait
Thu May 21, 2020 9:41 pm
Two different issues I think:
1/ I should run vimtutor to advance my vim skills - good idea, thanks!
2/ The default install of /usr/bin/vi should not dump unwanted characters into my text if I use the arrow keys while in insert mode
The silliness doesn't happen in Ubuntu 20.04, or in the the Gentoo for Raspbian that I've tried recently on my Pi, and it doesn't when I copy the /etc/vim/vimrc file to my home directory as .vimrc in Raspbian. (Or, perhaps these characters are a deliberate punishment to put me on to the true path to more enlightened vi editing?)
kerry_s
Thu May 21, 2020 10:16 pm
i think its a matter of how the distro chooses to compile/setup there version.
i've never navigated in "insert" in the many years i've used linux.
but then again i'm more use to moving around by # (example: 6j, 6w).
busywait
Thu May 21, 2020 11:03 pm
Ah, yep - sudo apt install vim does correct the arrow key behaviour too (the package is just vim, not vim-full) - also has vimtutor baked in to the help, thanks :)
Paeryn
Thu May 21, 2020 11:08 pm
Looking through the docs, the original vi behaviour was to switch the terminal to Application mode (changes the key codes that the cursor and number pad keys send) and to not use the cursor application keys for movement when in edit mode.
Vim's behaviour is to allow the cursor keys to be used as movement keys even when in edit mode, but if vim-tiny is installed then you don't get vim's improvements like this.
So at a guess if, when using vim-tiny in a terminal, the cursor keys work as movement keys in edit mode then the terminal is probably set up to not switch the cursor keys to Application mode when asked to.
I probably used to have the cursor keys mapped in edit mode back before I discovered vim with things like this in my .virc file
map! ^[OA ^[ka
bls
Contact: Twitter
Thu May 21, 2020 11:31 pm
Sigh...who would have thought it was a which-version-of-vim issue? Obviously not me! :oops:
PeterO
Fri May 22, 2020 6:30 am
PeterO
Thanks, I've never looked into it in that closely :-)
PeterO
busywait
Fri May 22, 2020 8:47 pm
:) Sorry, I misdirected you by showing an output from "apt info vim" in my first post. I've worked out how to query for the actually installed version of a binary now, and edited my post up above.
[email protected]:~ $ which vi
/usr/bin/vi
[email protected]:~ $ ls -l /usr/bin/vi
lrwxrwxrwx 1 root root 20 Feb 13 15:54 /usr/bin/vi -> /etc/alternatives/vi
[email protected]:~ $ ls -l /etc/alternatives/vi
lrwxrwxrwx 1 root root 17 Feb 13 15:54 /etc/alternatives/vi -> /usr/bin/vim.tiny
[email protected]:~ $ ls -l /usr/bin/vim.tiny
-rwxr-xr-x 1 root root 921704 Jun 15  2019 /usr/bin/vim.tiny
[email protected]:~ $ dpkg -S /usr/bin/vim.tiny
or
So, *vim-tiny*, the default package that provides vi in the Raspbian full install images, doesn't allow using cursor key navigation in insert mode, perhaps because it is missing a default.vim file. And I have two easy ways to make the problem go away.
Return to “Raspberry Pi OS”
