psrana
Help - R Pi Errors Boot Failing :-(
Sat Dec 29, 2012 2:18 pm
Set up :
Rev B. Kingston SDHC 32GB Class 10 (SD10G2.32GB) ulitmate X 100X loaded with 2012-12-16-wheezy-raspbian.img
Note - I checked the SD card was valid on http://www.raspberry-pi.co.uk/2012/06/0 ... -sd-cards/ before buying it.?
Not connected to LAN
Keyboard/mouse connected via Logitec USB Wireless - problem occurrs irrespective of this being connected
HDMI connected LG TV
I get the following warnings/errors : (not complete)
VFS: Cannot open root device "mmcblk0p2" or unknow-block(179,2)
Please append a correct "root=" boot option; here are the available partitions:
b300 30908416 mmcblk0 driver: mmcblk
Kernel panic - not syncingL VFS: Unable to mount root fs on unknown-block(179,2)
... loads of other messages..... eventually
PANIC: VFS: Unable to mount root fs on unknown-block(179,2)
Entering kdb due to Keyboard Entry (this is arrived at even without a keyboard plugged in)
kdb> (BUT I CANT actually input anything)
This happens on 2 R Pi units.
Any help/guidance appreciated..... i have a daughter who can't get to her xmas present :-(
regards,
Pawiter
psrana
Re: Help - R Pi Errors Boot Failing :-(
Mon Dec 31, 2012 11:22 am
Is there any chance of some support with this issue ?
Pawiter
jamiesk
Mon Dec 31, 2012 11:38 am
Have you another SD card to use? Its gotta be 4G or more.
Have you re-flashed the SD card, and checked its checksum on download?
What PSU are you using ?
I might not have the answers, but these will help others to assist.
Pi1 (Nov 2012 loft)= 1KW immersion controller for Solar panel
Pi2 (Jan 2013 living room)=Play thing
Pi3 (Feb 2013 mobile)= Play thing with Tandy Ladder board,breakout board,Nokia display
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=26&t=28193
psrana
Mon Dec 31, 2012 12:02 pm
Thanks for the help.
I haven't tried another - need to get one ...
The PSU is from RS HNP06UK-MicroUSB, 5.0V 1200mA
The checksum on the download I have just checked using SHA-1for http://downloads.raspberrypi.org/images ... spbian.zip and it doesn't match !
I have tried 2 futher downloads from different mirror sites and i get the same checksum.
I have tried a different image 2012-09-18.img and I get the same issue.
regards,
P
jamiesk
Mon Dec 31, 2012 12:43 pm
Sorry I did not help much to isolate your problem.
How about a different version to check ? Try Arch or RiscOS to make sure its the software... see the downloads at http://www.raspberrypi.org/downloads
psrana
Mon Dec 31, 2012 1:36 pm
Update .... I found a 2GB microSD Sandisk and loaded with 2012-12-16-wheezy-raspbian.img and its up !
So the Kingston 32GB SD10G2/32GB cards are not working, what a waste of money !!!
Can these be put on the need to be proven list because the information on the link of valid SD cards appears to be incorrect - happy to be corrected......
regards,
Pawiter
BobCochran
Mon Dec 31, 2012 1:54 pm
Hi! One possibility to me is that the contacts on the SD card are dirty and need to be cleaned. If you very gently wipe them with a damp cloth or "Q-tip" (a small cotton swab), the card might be able to boot. I try not to touch the contacts on my SD cards to keep my finger oils off the contacts.
Bob
eekamouse
Fri Jan 18, 2013 3:32 pm
Same problem here. Kingston SD10G2/32GB bought after checking the compatibility list. This card is not working with raspberry pi. The strange thing is that i managed to boot raspbian but only once!!! Since that no way to reproduce it. Waste of money...
SethCWhiting
Wed Sep 03, 2014 1:01 pm
I had the same problem until I followed this video step by step:
http://www.raspberrypi.org/help/noobs-setup/
Hope that helps!
