nickbouwhuis
Reset SD card
Sat Dec 29, 2012 12:53 pm
I flashed an Raspbian image to my SD card, but I am ready to reformat my SD card. The size is however 70 MB now (instead of 16GB)
How can I restore this?
Wheel_nut
Re: Reset SD card
Sat Dec 29, 2012 1:14 pm
That is because you are only seeing the Boot partition, the main partition being ext4 format and invisible to Windows.
If you are putting a new Image on the card using Win32DiskImager, just let Win32DiskImager overwrite it. It will do the re-format on the fly.
If you want to use the card as a FAT data card, the easiest way is to format it in a Digital Camera.
BerryPicker
Re: Reset SD card
Sat Dec 29, 2012 1:20 pm
I'm not sure if this is what you're wanting to do, but take a look at
http://elinux.org/RPi_raspi-config
and the option
EXPAND-ROOTFS - Expand Root Partition to Fill SD Card.
