steve1000
SD cards keep getting corrupted
Thu May 14, 2020 11:03 am
Hi all,
I'm fairly new to the raspberry and am a bit overwhelmed.
Here is my situation:
I am building a photogrammetry 3d scanner / cam array containing 60 ESP32s and 10 Raspberry Pi Zero Ws running Debian lite on cheap 16GB cards.
I power each module via pins from a stable 5V/40A PSU.
My scripts perform like they should BUT when after removing power from the system multiple Pis have corrupted SD cards.
I figure that the corruption comes from write processes during "shutdown".
My attempted solution so far:
- Load /var/logs as ram drive
- Write temporary image files to ram drive
does not work.
Is there maybe a safer approach? Are there other processes writing to storage? Any tips in general?
Thanks for your time!
ElEscalador
Re: SD cards keep getting corrupted
Thu May 14, 2020 11:39 am
Are you clicking the "shutdown" button or just pulling the plug?
Robotics tips, hacks, book extras https://youtube.com/practicalrobotics
steve1000
Thu May 14, 2020 11:49 am
I am just pulling the plug.
I do have a dedicated "sudo shut down now" available via UDP, but it does not seem to fix the issue.
ElEscalador
Thu May 14, 2020 12:36 pm
Just pulling the plug definitely leaves you at risk for killing power mid-write to the sd card which is the big corruptor. I thought sudo shutdown ensured everything was done...perhaps the -h (as in sudo shutdown -h now) is necessary to ensure everything has stopped, although I haven't had a problem without the -h.
wildfire
Thu May 14, 2020 4:19 pm
A few things I noticed in this thread...
1) "Cheap 16Gb cards, I guess that depends on your definition of Cheap.
2) "just pulling the plug", Defiantly a major cause of corruption.
3) Assuming this is a typo "sudo shut down now" (there is no space between shut & down), are you allowing enough time for a proper shutdown before pulling the plug?
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
steve1000
Fri May 15, 2020 9:04 am
Ok, I found a solution.
I enabled the overlay fs for the boot drive and everything works nicely
