Morning all
I am very much new to all of this, my Raspberry Pi 4 has only arrived today and I already have a project in mind that I feel the RPi 4 is capable of.....I may be wrong with my very limited knowledge but I'm hoping that's where some of you may be able to help.
So a few weeks back I bought myself a DJI Mavic Mini Drone and I love it....but I want more. Since I was a kid I have always looked at something and thought of how I could improve, modify or get more from it and this is exactly where I am at with the Mavic Mini so I will explain what I am trying to achieve.
The drone itself operates using Wifi, a mixture of 2.4 and 5.8 this also sends back the image from the drone to the receiver which then uses a Micro USB (from the receiver) to Type - C (to the mobile phone) in order to display the real-time footage on the phone so that you can see where you are flying. This has a few setbacks, screen glare in sunlight, phone needing to be in airplane mode for minimal interference.
So I wanted to use FPV goggles for an overall better and more immersive experience....this is where the issues arise. DJI do not want you to have that capability on their entry level drone and as a result their goggles are not compatible so that rules that's out and is what has led me onto my work around. I purchased a Fusion 5 Android tablet as it had an input and output source and was only £99.....bargain.
When I installed the app it was apparent that the tablet barely scraped through the running requirements and as a result I was suffering from latency issues of over a second or two. This was told was down to the specs which are as follows.
FUSION 5
· 64-bit quad-core ARM Cortex-A53 MPCore 1.3ghz and 3D graphics at (OpenGL ES 3.1)
· 2GB RAM
.32gb storage.
Raspberry Pi 4
.quad-core Cortex-A72 (ARM v8) 64-bit at 1.5GHz.
. 4GB RAM
. 32gb storage (will run at 64gb card though)
DJI Fly APP Requirements
. Requires Android 6.0 or above
. Available ROM is 2GB
. Supporting ARM V8 64-bit Architecture (64-bit processor)
so from what I can tell (again very basic knowledge) It looks like the Pi would well out perform the Fusion 5. The Arm Cortex A72 is superior performance over the A53 that's more for efficiency.
So my plan is as follows, use a RPi 4 with a 3.5 display ( understand there will be latency due to the screen not the Pi and may upgrade to 7" later) that will have the DJI app installed that will replace the need for a phone and connect to the Transmitter, I will then use the HDMI port on the RPi to run a cable to the HDMI input on the goggles where the screen will be capable of running the image without any latency.
So onto my questions.
First and foremost am I way off and this wouldn't work?
How should I install the DJI Fly App onto my RPi, I am assuming I would need to put android software on and then download or can I just install the software direct?
Thanks in advance.
