nemo096
Simple Perl Command
Fri Dec 28, 2012 11:53 pm
I have written a few long Perl scripts on Windows and am going to add these to my other scripts on my Pi but I have a problem
In a few of my scripts I require a log on screen and to do this I used
system("cls");
to clear the screen and then prompt for username and password but now when I use Geany and enter than line the screen won't change
Is there a different command for clearing the screen on the Pi?
Ethan
jojopi
Re: Simple Perl Command
Sat Dec 29, 2012 12:25 am
You can use either of:
system "clear";
system "tput", "clear";
(It is debatable which of these is more portable.)
However, the only advantage of using an external program is support for weird terminals. In practice all modern terminal emulators use mostly ANSI/VT100 escape sequences, so you may print them yourself:
print "\e[H\e[J";
nemo096
Sat Dec 29, 2012 1:16 pm
Thanks jojopi -
system("clear")
worked perfectly.
Just to clear this up for myself anything i have inside a
system("")
should be a terminal command?
