I have problem with enabling GL on my RPI 3B+(8.0 jessie). I have read thousand of articles, but nothing helped me with my problem. Even after all manipulations with RPI i did not see item "Enable OpenGL" in raspi-config/advanced options. Unfortunately, i can not use another image for RPI because we use it in produaction, Generally, i stuck with the issue. RPI is new for me and during my research i could miss some important settings/packages. May be some one can help to figure out what is wrong with system - check important settings, packages etc.
root@rpi:~# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
A1 Overscan You may need to configure oversca │
│ A2 Hostname Set the visible name for this Pi │
│ A3 Memory Split Change the amount of memory made │
│ A4 SSH Enable/Disable remote command lin │
│ A5 Device Tree Enable/Disable the use of Device │
│ A6 SPI Enable/Disable automatic loading │
│ A7 I2C Enable/Disable automatic loading │
│ A8 Serial Enable/Disable shell and kernel m │
│ A9 Audio Force audio out through HDMI or 3 │
│ A0 Update Update this tool to the latest ve │
│ <Select> <Back>
