gordon77
Why does this lock up / crash the Pi ?
Sat May 09, 2020 10:57 am
This script takes pictures with the PI Camera using raspistill as a subprocess, and you can set the shutter speed.
But after a while and longer shutter speeds it crashes the Pi, anyone identify why ?
I stop and restart the subprocess with a new shutter speed, and verify a valid jpg file, hopefully to determine its complete before loading.
#!/usr/bin/env python3
import os
import pygame, sys
import time
import shutil
import subprocess, glob
import signal
import tkinter as tk
from PIL import ImageTk, Image
class MainApplication(tk.Frame):
    def __init__(self, master):
        self.master = master
        tk.Frame.__init__(self, self.master)
        self.ss = 100000
        if os.path.exists('/run/shm/test.jpg'):
            os.rename('/run/shm/test.jpg', '/run/shm/oldtest.jpg')
        rpistr = "raspistill -w 640 -h 480 -t 0 -tl 0 -bm -n -o /run/shm/test.jpg -ex off -ss " + str(self.ss)
        self.p = subprocess.Popen(rpistr, shell=True, preexec_fn=os.setsid)
        time.sleep(1)
        self.dataure_gui()
        self.create_frames()
        self.create_buttons()
    def dataure_gui(self):
        self.master.title('Shutter Speed Selection')
        self.master.geometry('640x520')
        self.master.resizable(0, 0)
    def create_frames(self):
        self.Frame10 = tk.Frame(width=800, height=600)
        self.Frame10.grid_propagate(0)
        self.Frame10.grid(row=0, column=0)
    def create_buttons(self):
        self.B1 = tk.Button(self.Frame10, text='SS_Down',  command = self.SS_Down)
        self.B1.grid(row=0, column=0)
        self.SS = tk.Label(self.Frame10, text = str(int(self.ss/1000)) + " mS")
        self.SS.grid(row=0, column=1)
        self.B2 = tk.Button(self.Frame10, text=' SS_Up ',command = self.SS_Up)
        self.B2.grid(row=0, column=2)
        self.B3 = tk.Button(self.Frame10, text='EXIT',command = self.Exit)
        self.B3.grid(row=0, column=3)
        self.load = Image.open("/run/shm/test.jpg")
        self.renderc = ImageTk.PhotoImage(self.load)
        self.img = tk.Label(self.Frame10, image = self.renderc)
        self.img.grid(row = 1, column = 0, columnspan = 4, rowspan = 5, pady = 2)
        self.Display()
    def Display(self):
            try:
                self.load.verify()
                self.img.config(image = self.renderc)
            except (IOError, SyntaxError) as e:
                print('Bad file:', filename)
        self.after(200, self.Display)
    def SS_Down(self):
        self.ss -= 100000
        if self.ss < 100000:
            self.ss = 100000
        self.Restart()
    def SS_Up(self):
        self.ss += 100000
        if self.ss > 6000000:
            self.ss = 6000000
        self.Restart()
    def Restart(self):
        self.SS.config(text = str(int(self.ss/1000)) + " mS")
        os.killpg(self.p.pid, signal.SIGTERM)
    def Exit(self):
        self.master.destroy()
if __name__ == '__main__':
    root = tk.Tk()
    main_app =  MainApplication(root)
    root.mainloop()
Re: Why does this lock up / crash the Pi ?
Sat May 09, 2020 11:49 am
Why are you spawning raspistill rather than using the python picamera module?
Are you sure you've terminated all of those spawned processes when each one is done capturing your new image?
gordon77
Sat May 09, 2020 11:53 am
There is only one subprocess running at a time and yes it's terminated as required.
I've added 2 steps to ensure the subprocess is stopped, and restarted. Still crashes.
import os
import pygame, sys
import time
import shutil
import signal
        self.ss = 100000
        time.sleep(1)
        self.dataure_gui()
        self.Display()
    def Display(self):
            try:
                self.load.verify()
    def SS_Down(self):
        self.ss -= 100000
            self.ss = 100000
        self.Restart()
    def SS_Up(self):
        self.ss += 100000
            self.ss = 6000000
        self.Restart()
    def Restart(self):
        poll = self.p.poll()
        while poll == None: # subprocess still running
            time.sleep(.1)
        while poll != None: # ensure subprocess running
            time.sleep(.1)
    def Exit(self):
    root = tk.Tk()
    root.mainloop()
gordon77
Fri May 22, 2020 1:58 pm
amazingadmin wrote:
Fri May 22, 2020 6:46 am
I recommend you to learn about https://rawpython.com/tkinter-label/ from this awesome tutorial.
Thanks, to learn what ?
Idahowalker
Fri May 22, 2020 3:39 pm
Have you used task manager to confirm that all the processes are shutting down? You can, also, monitor memory use and CPU use vs time.
There are come CLI thingies that will give 'better' info of the happenings.
Without knowing why you are deleting my postings, I will not know how...
gordon77
Fri May 22, 2020 5:45 pm
Thanks, l'll look further for details
gordon77
Sat May 23, 2020 10:00 am
I have looked further at this, and modified the script so it stops the subprocess whenever I change a parameter, and I check with Task manager it has stopped, I then restart the subprocess. Still it crashes the Pi, with shutter times > 1 second usually.
No excess CPU / RAM use shown.
I can only assume its a raspistill issue ?
import os
import pygame, sys
import time
import shutil
import signal
        self.ss = 10000
        self.ISO = 0
        self.mode = 1
        self.Br = 50
        self.Co = 0
        self.modes =  ['off',  'auto', 'night', 'sports', 'verylong', 'fireworks']
        rpistr = "raspistill -w 640 -h 480 -t 0 -tl 0 -n -ISO 0 -o /run/shm/test.jpg -br " +  str(self.Br) + " -co " + str(self.Co) + " -ex " + self.modes[self.mode] + " -ss " + str(self.ss)
        time.sleep(2)
        self.dataure_gui()
        self.master.geometry('640x600')
        self.B1 = tk.Button(self.Frame10, text='SS_Dn',  command = self.SS_Down,repeatdelay=100, repeatinterval=50)
        self.B2 = tk.Button(self.Frame10, text=' SS_Up ',command = self.SS_Up,repeatdelay=100, repeatinterval=50)
        self.C1 = tk.Button(self.Frame10, text='ISO_Dn',  command = self.ISO_Down,repeatdelay=1000, repeatinterval=500)
        self.C1.grid(row=1, column=0)
        self.CS = tk.Label(self.Frame10, text = str(self.ISO))
        self.CS.grid(row=1, column=1)
        self.C2 = tk.Button(self.Frame10, text=' ISO_Up ',command = self.ISO_Up,repeatdelay=1000, repeatinterval=500)
        self.C2.grid(row=1, column=2)
        self.M1 = tk.Button(self.Frame10, text='Mode_Dn',  command = self.Mode_Down,repeatdelay=1000, repeatinterval=500)
        self.M1.grid(row=1, column=3)
        self.MS = tk.Label(self.Frame10, text = self.modes[self.mode])
        self.MS.grid(row=1, column=4)
        self.M2 = tk.Button(self.Frame10, text=' Mode_Up ',command = self.Mode_Up,repeatdelay=1000, repeatinterval=500)
        self.M2.grid(row=1, column=5)
        self.D1 = tk.Button(self.Frame10, text='Br_Dn',  command = self.Br_Down,repeatdelay=1000, repeatinterval=500)
        self.D1.grid(row=2, column=0)
        self.DS = tk.Label(self.Frame10, text = str(self.Br))
        self.DS.grid(row=2, column=1)
        self.D2 = tk.Button(self.Frame10, text=' Br_Up ',command = self.Br_Up,repeatdelay=1000, repeatinterval=500)
        self.D2.grid(row=2, column=2)
        self.E1 = tk.Button(self.Frame10, text='Co_Dn',  command = self.Co_Down,repeatdelay=1000, repeatinterval=500)
        self.E1.grid(row=2, column=3)
        self.ES = tk.Label(self.Frame10, text = str(self.Co))
        self.ES.grid(row=2, column=4)
        self.E2 = tk.Button(self.Frame10, text=' Co_Up ',command = self.Co_Up,repeatdelay=1000, repeatinterval=500)
        self.E2.grid(row=2, column=5)
        self.R1 = tk.Button(self.Frame10, text=' Retstart ',command = self.Restart)
        self.R1.grid(row=2, column=6)
        self.img.grid(row = 4, column = 0, columnspan = 8, rowspan = 5, pady = 2)
        self.Display()
    def Display(self):
            try:
                self.load.verify()
    def SS_Down(self):
        if self.ss < 20000:
            inc = 1000
        elif self.ss >= 20000 and self.ss <= 490000:
            inc = 10000
        elif self.ss > 490000 and self.ss <= 1000000:
            inc = 100000
        elif self.ss > 1000000:
            inc = 1000000
        self.ss -= inc
        if self.ss < 1000:
            self.ss = 1000
        self.Stop()
    def SS_Up(self):
        if self.ss < 20000:
            inc = 1000
            inc = 10000
            inc = 100000
            inc = 1000000
        self.ss += inc
            self.ss = 6000000
        self.Stop()
    def ISO_Down(self):
        self.ISO -= 100
        if self.ISO < 0:
            self.ISO = 0
        self.CS.config(text = str(self.ISO))
        self.Stop()
    def ISO_Up(self):
        self.ISO += 100
        if self.ISO > 800:
            self.ISO = 800
        self.Stop()
    def Mode_Down(self):
        self.mode -= 1
        if self.mode < 0:
            self.mode = 0
        self.MS.config(text = self.modes[self.mode])
        self.Stop()
    def Mode_Up(self):
        self.mode += 1
        if self.mode > 5:
            self.mode = 5
        self.Stop()
    def Br_Down(self):
        self.Br -= 1
        if self.Br < 0:
            self.Br = 0
        self.DS.config(text = str(self.Br))
        self.Stop()
    def Br_Up(self):
        self.Br += 1
        if self.Br > 100:
            self.Br = 100
        self.Stop()
    def Co_Down(self):
        self.Co -= 1
        if self.Co < -50:
            self.Co = -50
        self.ES.config(text = str(self.Co))
        self.Stop()
    def Co_Up(self):
        self.Co += 1
        if self.Co > 50:
            self.Co = 50
        self.Stop()
    def Stop(self):
        if poll == None: # subprocess still running
        while poll == None: # ensure subprocess stopped
            time.sleep(.1)
        self.R1.config(bg = "red")
    def Restart(self):
        if poll == None: # subprocess running
            time.sleep(.1)
        rpistr = "raspistill -w 640 -h 480 -t 0 -tl 0 -bm -n -ISO " + str(self.ISO) + " -o /run/shm/test.jpg -br " +  str(self.Br) + " -co " + str(self.Co) + " -ex " + self.modes[self.mode] + " -ss " + str(self.ss)
            time.sleep(.1)
        self.R1.config(bg = "light grey")
    def Exit(self):
    root = tk.Tk()
    root.mainloop()
Idahowalker
Sat May 23, 2020 10:53 am
WHen you write change a parameter, are you 'saying' that the sub process is running and you, in some way, send it a new thing do and then the sub process stops? Have you tried sending data to the sub process through a queue?
gordon77
Sat May 23, 2020 10:56 am
The subprocess is running, I change the parameter value, then stop the process, and then restart it (another button) with new parameters.
example
    def SS_Down(self):
        if self.ss < 20000:
            inc = 1000
            inc = 10000
            inc = 100000
            inc = 1000000
        self.ss -= inc
        if self.ss < 1000:
            self.ss = 1000
        self.Stop()
Idahowalker
Sat May 23, 2020 12:49 pm
I'd try to inject parameter, if possible, changes whiles the processes are running using a queue.
gordon77
Sat May 23, 2020 4:05 pm
Can you give me an idea how to do that ?
I tried starting the subprocess with..
self.p = subprocess.Popen(['raspistill','-w','640','-h','480','-t','0','-tl','0','-n','-ISO','0','-o','/run/shm/test.jpg'], preexec_fn=os.setsid, stdin=subprocess.PIPE)
which works OK
but how do I get different parameters to it when running ?
I tried self.p.stdin.write(b' -ss 1000000') but it didn't work
gordon77
Sun May 24, 2020 10:35 am
I tried using picamera, anyone know why cv2.setMouseCallback(winName,onmouse) won't work with it ?
# import the necessary packages
from picamera.array import PiRGBArray
from picamera import PiCamera
import time
import cv2
width = 640
height = 480
winName = "Frame"
def onmouse(event,x,y,flags,params):
  if event == cv2.EVENT_LBUTTONDOWN:
      print (x,y)
# initialize the camera and grab a reference to the raw camera capture
camera = PiCamera()
camera.resolution = (width, height)
camera.framerate = 30
rawCapture = PiRGBArray(camera, size=(width, height))
# allow the camera to warmup
time.sleep(1)
# capture frames from the camera
for frame in camera.capture_continuous(rawCapture, format="bgr", use_video_port=True):
# grab the raw NumPy array representing the image, then initialize the timestamp
# and occupied/unoccupied text
    image = frame.array
    cv2.imshow(winName,image)
    key = cv2.waitKey(1) & 0xFF
    # clear the stream in preparation for the next frame
    rawCapture.truncate(0)
    # if the `q` key was pressed, break from the loop
    if key == ord("q"):
        break
Return to “Python”
