The gaps are constantly spaced, and happen almost always, although there were a few exceptions when the recording was uninterrupted. The hickups are short, but clearly disruptive to any reasonable recording, even just for voice calls.
I have tried two devices:
1) Jabra 510+ (using both wireless and wired connection)
2) SoundBlaster X-Fi Surround 5.1
Given that two very dissimilar USB devices presented the same problem, I have also tried plugging into USB2.0 ports, USB3.0 ports, turning off BT and WiFi while recording. I have also tried unplugging essentially all other USB devices. I have received the same results in each experiment.
As a baseline, I have tried using Audacity with the Jabra 510+ on another computer. Recording was flawless.
I'm kind of at a loss where to even start. My knowledge of USB stack is pretty much non-existent, but I'm happy to shotgun-debug with any ideas anyone might have -- module parameters, firmware versions, power saving options, etc.
