I have a Pi 3 that will conenct to WiFi. It's model is Pi3 Model B V1.2. I have set up the "wpa_supplicant" file as follows:
country=GB
update_config=1
ctrl_interface=/var/run/wpa_supplicant
network={
ssid="SSID OF MY WIFI"
psk="PASSWORD OF MY WIFI NETWORK"
That I found on https://randomnerdtutorials.com/cctv-ra ... tioneyeos/
Any ideas where I am going wrong?
- Contact: Website
Re: Unable to connect Pi3 to wiFi
Is your WIFI router 2.4GHz or dual band?
The RPi3B is 2.4GHz only.
Its dual band and I have 2 other Rpi Model 3s that connect just fine just this one is being a pain!
- HawaiianPi
Your wpa_supplicant.conf seems to be missing something.
Here's an example of what mine looks like (notice GROUP=netdev that's missing in yours).
update_config=1
country=GB
network={
ssid="2.4GHz WiFi SSID"
psk="2.4GHz WPA/WPA2 passphrase"
network={
ssid="5GHz WiFi SSID"
psk="5GHz WPA/WPA2 passphrase"
network={
ssid="Mobile hotspot SSID"
psk="Mobile hotspot WPA/WPA2 passphrase"
I will try that, cheers pal!
Check out the newer tutorial from dronebotworkshop: https://dronebotworkshop.com/motioneyeos-raspberry-pi/
The wpa_supplicant.conf that you have to put on the SD card before you stick it in the pi is a preconfiguration file , the rest of the stuff gets put in by motioneyeos when it boots up.
assuming you are in the US, here is what the preconfiguration file looks like:
country=us
update_config=1
network={
scan_ssid=1
ssid="yyyyy"
psk="zzzzz"
Don"t forget the closing }.
I set mine up in Notepad on a Win10 computer. You will only see the FAT32 file on the flashed SD so you don't have to worry about getting it in the wrong partition - Windows10 doesn't recognize ext-4 format. Be sure to save as a .conf file (leave the .txt off). Plan on flashing the SD card several times since every time you boot it, motioneyeos writes to the SD card (adds to wpa_supplicant.conf) and every error requires a new re-do.
I recommend you download the pdf that accompanies the tutorial and print out pages 23 through 37 if you are as much a noob as I am and old enough to suffer from short term memory issues. Speaking of flashing, the quickest and best I've found is etcher. No pre-formatting necessary and it is just dead simple, and fast for the image I downloaded. I have the NoIR v. 2 on an R Pi 1B and it works fine although the 1B Pi is very slow. I have just finished getting the static IP address up and running so now I will put the Pi & camera in a box and set it up to watch the rodents play.
country=us
update_config=1
network={
scan_ssid=1
ssid="yyyyy"
psk="zzzzz"
