It just might, but...Botspot wrote: ↑Wed Apr 29, 2020 9:59 pmYeah I don't think dpkg auto-installs dependencies. Maybe apt does, but IDK.Code: Select all
sudo apt install browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb
$ sudo apt install ./browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'browser-plugin-freshplayer-pepperflash' instead of './browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
browser-plugin-freshplayer-pepperflash : Depends: libavcodec-ffmpeg56 (>= 7:2.4) but it is not installable or
libavcodec-ffmpeg-extra56 (>= 7:2.4) but it is not installable
Depends: libavutil-ffmpeg54 (>= 7:2.4) but it is not installable
Depends: libevent-2.0-5 (>= 2.0.10-stable) but it is not installable
Depends: libevent-pthreads-2.0-5 (>= 2.0.10-stable) but it is not installable
Depends: libssl1.0.0 (>= 1.0.0) but it is not installable
Depends: libva-x11-1 (>= 1.0.3) but it is not installable
Depends: libva1 (>= 1.2.0) but it is not installable
Recommends: pepperflashplugin-nonfree but it is not installable
E: Unable to correct problems, you have held broken packages.Code: Select all
s$ sudo apt install ./browser-plugin-freshplayer-pepperflash_0.3.5-1ubuntu7_arm64.deb
Note, selecting 'browser-plugin-freshplayer-pepperflash' instead of './browser-plugin-freshplayer-pepperflash_0.3.5-1ubuntu7_arm64.deb'
browser-plugin-freshplayer-pepperflash : Depends: libavcodec57 (>= 7:3.4.1) but it is not installable or
libavcodec-extra57 (>= 7:3.4.1) but it is not installable
Depends: libavutil55 (>= 7:3.4.1) but it is not installable
Recommends: adobe-flashplugin but it is not installable
