Yes, default Raspbian includes a flash player by default. Also, browsing in Raspbian is usually faster since it's HW accelerated.
Yes it does. Raspbian Does. Ubuntu does not IIRC.
Yes. In fact, chromium will even tell you where its flash player is located at chrome://version. In "Command Line:", you will see this:
--ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=32.0.0.330That makes it urgent for *you*, but not for anyone else here. Urgency is relative.graf_eberstein wrote: ↑Tue Apr 28, 2020 3:37 am4) Deadlines beget urgency; to say "nothing is urgent" is unhelpful and asinine.
graf_eberstein wrote: ↑Tue Apr 28, 2020 3:37 amI'm going to respond to all these replies in one sitting, so please bear with me...
1) Raspbian is not an option for that Pi.
2) Chromium is required by the district.
3) The resource uses Flash, no way around it.
Regarding the serious suggestion of "borrowing" files from a Raspbian image: Does it have to be off the Buster release, or can it come from an older one? Asking because I'm running short on SD cards currently (more are on order, but they won't be here in time). I do have one working Raspbian setup, but it is the previous release.
I like your concise writing style!graf_eberstein wrote: ↑Tue Apr 28, 2020 3:37 am1) Raspbian is not an option for that Pi.
I have no idea. To stay on the safe side, I would suggest you copy the files from a Buster release. Actually, you don't need to flash it to an sd card to grab the file. If you have ~7 GB free space, you could download a Raspbian Full image, mount it using something like PPT, and snatch the file out.graf_eberstein wrote: ↑Tue Apr 28, 2020 3:37 amRegarding the serious suggestion of "borrowing" files from a Raspbian image: Does it have to be off the Buster release, or can it come from an older one? Asking because I'm running short on SD cards currently (more are on order, but they won't be here in time). I do have one working Raspbian setup, but it is the previous release.
chromium --ppapi-flash-path=/usr/lib/chromium/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=32.0.0.330Hehe... thanks!
Thank you SO MUCH for this! I just grabbed that file and moved it over. The only thing I'm (understandably) uncertain about is the mask and ownership the file should have. I'm going out on a limb and guess 644 and root:root respectively (there are .so files in other directories with a different mask, otherwise it'd be a no-brainer), so I set them as such for testing. If this works, I'll leave it be and move on.Botspot wrote: ↑Tue Apr 28, 2020 12:38 pmI have no idea. To stay on the safe side, I would suggest you copy the files from a Buster release. Actually, you don't need to flash it to an sd card to grab the file. If you have ~7 GB free space, you could download a Raspbian Full image, mount it using something like PPT, and snatch the file out.
Or, to save you some effort, I've attached my Raspbian's libpepflashplayer.so right here.
So after downloading it, copy it to /usr/lib/chromium.
And then to run chromium with flash, use this command:Code: Select all
I'm well aware that this is just a shot that has a 50/50 chance of working and do appreciate the effort.
sudo ln -s /usr/lib/chromium-browser /usr/lib/chromiumUpdate: I just got done getting everything set up, and there's some progress! Gone is the "This site requires Adobe Flash" failover message that's been plaguing me. It's been replaced with the blank page displaying the grey puzzle-piece and "Right Click to run Adobe Flash Player". But when I right click as instructed and select "Run this plugin", nothing happens.
chromium --ppapi-flash-path=/usr/lib/chromium/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=32.0.0.330 2>errors.txtCode: Select all
Gtk-Message: 12:01:27.660: Failed to load module "appmenu-gtk-module"
Gtk-Message: 12:01:27.662: Failed to load module "canberra-gtk-module"
[11988:11988:0428/120127.773241:ERROR:edid_parser.cc(102)] Too short EDID data: manufacturer id
[11988:12134:0428/120127.848143:ERROR:object_proxy.cc(632)] Failed to call method: org.freedesktop.DBus.ListActivatableNames: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.AccessDenied: An AppArmor policy prevents this sender from sending this message to this recipient; type="method_call", sender=":1.148" (uid=1002 pid=11988 comm="/snap/chromium/1131/usr/lib/chromium-browser/chrom" label="snap.chromium.chromium (enforce)") interface="org.freedesktop.DBus" member="ListActivatableNames" error name="(unset)" requested_reply="0" destination="org.freedesktop.DBus" (bus)
[11988:11988:0428/120128.043139:ERROR:browser_switcher_service.cc(238)] XXX Init()
[12136:12136:0428/120128.298317:ERROR:viz_main_impl.cc(159)] Exiting GPU process due to errors during initialization
[11988:12117:0428/120133.078289:ERROR:udev_watcher.cc(96)] Failed to begin udev enumeration.
[13072:1:0428/120304.359521:ERROR:ppapi_thread.cc(310)] Failed to load Pepper module from /usr/lib/chromium/libpepflashplayer.so (error: /usr/lib/chromium/libpepflashplayer.so: cannot open shared object file: Operation not permitted)
Oh, the directory is /usr/lib/chromium-browser in Ubuntu as well? OK my bad. Go ahead and put it there then.graf_eberstein wrote: ↑Tue Apr 28, 2020 3:28 pmAside from the 32 vs 64 bit business: You said to park it in /usr/lib/chromium, but the (snap) install created /usr/lib/chromium-browser so I put the file in there.
That above error looks to be the only relevant one.graf_eberstein wrote: ↑Tue Apr 28, 2020 3:49 pmThe errors.txt file captured the following:Code: Select all
pi@raspberrypi:~ $ ls -l /usr/lib/chromium-browser/libpepflashplayer.so
-rw-r--r-- 1 root root 20150608 Mar 27 17:24 /usr/lib/chromium-browser/libpepflashplayer.so
pi@raspberrypi:~ $ stat -c '%A %a %n' /usr/lib/chromium-browser/libpepflashplayer.so
-rw-r--r-- 644 /usr/lib/chromium-browser/libpepflashplayer.soNo worries; I did so. I think the path and package names are chromium-browser because there's a game called Chromium, and that would cause confusion... LOL! I know from experience that filepaths can differ from distribution to distribution (even within distribution families like Debian, or releases thereof). I encountered this when I added the libraspberrypi-bin package (/opt/vc to /usr) and couldn't get HPLIP to install plugins (/usr/lib/aarch64-linux-gnu to /usr/lib/sane). In other words, nothing new (or is that, GNU?
I get:Botspot wrote: ↑Tue Apr 28, 2020 4:31 pmOperation not permitted sounds like a permission error to me. I went ahead and checked the file permission of my libpepflashplayer.so, and its permissions are:So see if yours matches. If it does match, then I'm not sure what else to try.Code: Select all
pi@raspberrypi:~ $ ls -l /usr/lib/chromium-browser/libpepflashplayer.so -rw-r--r-- 1 root root 20150608 Mar 27 17:24 /usr/lib/chromium-browser/libpepflashplayer.so pi@raspberrypi:~ $ stat -c '%A %a %n' /usr/lib/chromium-browser/libpepflashplayer.so -rw-r--r-- 644 /usr/lib/chromium-browser/libpepflashplayer.so
-rw-r--r-- 1 root root 20150608 Apr 28 10:57 libpepflashplayer.so
-rw-r--r-- 644 /usr/lib/chromium-browser/libpepflashplayer.soAt this point, I'm googling my way around.graf_eberstein wrote: ↑Tue Apr 28, 2020 9:14 pmThis may sound dumb, but do I need more than the .so file on the system?
sudo ldconfig -vCode: Select all
apt search pepper
apt search flashHere are the results:Botspot wrote: ↑Tue Apr 28, 2020 10:21 pmAt this point, I'm googling my way around.
Here's something to try:There's a small chance that a flash player package is available. Post the output of these commands:Code: Select all
apt search pepper apt search flash
Sorting...
Full Text Search...
burgerspace/eoan 1.9.2-3 arm64
Avoid evil foodstuffs and make burgers
libjs-jquery-ui-theme-pepper-grinder/eoan 1.12.1+dfsg-1 all
Pepper Grinder theme for jQuery UI
libwebkit2gtk-4.0-37-gtk2/eoan-updates,eoan-security 2.28.1-0ubuntu0.19.10.1 all
Transitional dummy package
pepper/eoan 0.3.3-3 arm64
Source code repository statistics and report tool
salt-pepper/eoan 0.5.5-1 all
Library and stand-alone CLI tools to access a salt-api instance
Sorting...
Full Text Search...
0xffff/eoan 0.8-1 arm64
Open Free Fiasco Firmware Flasher
air-quality-sensor/eoan 0.1.4.2-1 arm64
user space driver for AppliedSensor's Indoor Air Monitor
airspy/eoan 1.0.9-3 arm64
Tiny and efficient software defined radio receiver - utilities
amideco/eoan 0.31e-3.1build1 arm64
Decompress flashfiles equipped with an AMI BIOS
anki/eoan 2.1.8+dfsg-1ubuntu1 all
extensible flashcard learning program
avrp/eoan 1.0beta3-7build1 arm64
Programmer for Atmel AVR microcontrollers
awardeco/eoan 0.2-3.1build1 arm64
Decompress flashfiles equipped with an AWARD BIOS
bilibop/eoan 0.5.6 arm64
run Debian GNU/Linux from external media - metapackage
bilibop-common/eoan 0.5.6 arm64
shell functions for bilibop scripts
bilibop-lockfs/eoan 0.5.6 arm64
lock filesystems and write changes into RAM
bilibop-rules/eoan 0.5.6 arm64
device management rules for OS running from external media
bilibop-udev/eoan 0.5.6 arm64
minimal udev rule for Debian GNU/Linux running from external media
bleachbit/eoan,now 2.2-3 all [installed]
delete unnecessary files from the system
bmap-tools/eoan 3.5-2 all
tool to flash image files to block devices using the block map
bossa/eoan 1.3~20120408-5.1build1 arm64
Atmel SAM ARM microcontroller flash programming GUI
bossa-cli/eoan 1.3~20120408-5.1build1 arm64
Atmel SAM ARM microcontroller flash programming utility
budgie-countdown-applet/eoan-updates 0.10.1-0ubuntu4 all
Applet providing a countdown capability on the Budgie Desktop
budgie-dropby-applet/eoan-updates 0.10.1-0ubuntu4 all
Applet to popup when a USB device is connected
busybox-syslogd/eoan 1:1.30.1-4ubuntu4 all
Provides syslogd and klogd using busybox
byzanz/eoan 0.3.0+git20160312-3 arm64
small screencast creator
cbootimage/eoan 1.8-1 arm64
Tools to dump and generate boot config table on Tegra devices
crtmpserver/eoan 1.0~dfsg-5.5 arm64
High performance RTMP/RTSP streaming server
crtmpserver-apps/eoan 1.0~dfsg-5.5 arm64
base applications for the crtmpserver platform
crtmpserver-dev/eoan 1.0~dfsg-5.5 arm64
Development files for the crtmpserver platform
crtmpserver-libs/eoan 1.0~dfsg-5.5 arm64
shared libraries for the crtmpserver platform
cryptmount/eoan 5.3.1-1 arm64
Management of encrypted file systems
dell-recovery/eoan 1.63 all
Dell Recovery Media Creation Package
dfu-programmer/eoan 0.6.1-1build1 arm64
device firmware update (DFU) based USB programmer for Atmel chips
diskscan/eoan 0.20-1build1 arm64
scan storage media for bad or near failure sectors
duktape/eoan 2.4.0-1 arm64
embeddable Javascript engine
esptool/eoan 2.6+dfsg-1 all
create and flash firmware files to ESP8266 and ESP32 chips
f2fs-tools/eoan 1.11.0-1.1 arm64
Tools for Flash-Friendly File System
f2fs-tools-dbg/eoan 1.11.0-1.1 arm64
Tools for Flash-Friendly File System (debug)
f3/eoan 7.1-1 arm64
test real flash memory capacity
faifa/eoan 0.2~svn82-1build2 arm64
manage HomePlug 1.0/AV devices via ethernet frames
falkon/eoan 3.1.0-0ubuntu1 arm64
lightweight web browser based on Qt WebEngine
fastboot/eoan 1:8.1.0+r23-5 arm64
Android fastboot tool
firmware-microbit-micropython/eoan 1.0.1-1 all
MicroPython runtime for the BBC micro:bit
firmware-microbit-micropython-dl/eoan 1.2.4+dfsg-1 all
micro:bit MicroPython runtime downloader
firmware-microbit-micropython-doc/eoan 1.0.1-1 all
MicroPython runtime for the BBC micro:bit (documentation)
flash-kernel/eoan-updates,now 3.98ubuntu5.3 arm64 [installed,automatic]
utility to make certain embedded devices bootable
flashbake/eoan 0.27.1-0.1 all
automated snapshots with git
flashbench/eoan 62-1build1 arm64
identify flash storage properties
flashproxy-client/eoan 1.7-4 all
Pluggable transport to circumvent IP address blocking - client transport plugin
flashproxy-common/eoan 1.7-4 all
Pluggable transport to circumvent IP address blocking - common library
flashproxy-facilitator/eoan 1.7-4 all
Pluggable transport to circumvent IP address blocking - facilitator
flashproxy-proxy/eoan 1.7-4 all
Pluggable transport to circumvent IP address blocking - browser proxy
flashrom/eoan 1.1-1 arm64
Identify, read, write, erase, and verify BIOS/ROM/flash chips
flasm/eoan 1.62-10 arm64
assembler and disassembler for Flash (SWF) bytecode
flvstreamer/eoan 2.1c1-1build1 arm64
command-line RTMP client
fotoxx/eoan 18.07.2-1 arm64
easy-to-use digital photo editor
fotoxx-common/eoan 18.07.2-1 all
easy-to-use digital photo editor - common files
ftdi-eeprom/eoan 1.4-2 arm64
Tool for reading/erasing/flashing FTDI USB chip EEPROMs
get-flash-videos/eoan 1.25.99.03-1 all
video downloader for various Flash-based video hosting sites
gnome-flashback/eoan-updates 3.34.0-1ubuntu1.1 arm64
helper application for the GNOME Flashback session
gnome-flashback-common/eoan-updates 3.34.0-1ubuntu1.1 all
GNOME Flashback helper application - common data files
gnome-panel/eoan 1:3.34.0-1ubuntu1 arm64
traditional panel, used in GNOME Flashback
gnome-panel-data/eoan 1:3.34.0-1ubuntu1 all
common files for GNOME Panel
gnome-session-flashback/eoan-updates 1:3.34.0-1ubuntu1.1 all
traditional desktop session based on GNOME technologies
gnome-twitch/eoan 0.4.1-3 arm64
GNOME Twitch app for watching Twitch.tv streams without a browser or flash
golang-github-gorilla-sessions-dev/eoan 1.1+git20170802.7.b61c93c-3 all
save cookie and filesystem sessions and allow custom session backends
gplanarity/eoan 17906-7 arm64
simple puzzle game involving untangling planar graphs
granule/eoan 1.4.0-7-9 arm64
flashcard program for learning new words
granule-docs/eoan 1.1.0+dfsg-3 all
flashcard program for learning new words -- documentation
grub-customizer/eoan 5.1.0-1 arm64
GUI to configure GRUB2 and BURG
hackrf/eoan 2018.01.1-2 arm64
Software defined radio peripheral - utilities
hdmi2usb-fx2-firmware/eoan 0.0.0~git20151225-2 all
FX2 firmware for hdmi2usb board development
hdmi2usb-mode-switch/eoan 0.0.1-2 all
Configuration and firmware tool for HDMI2USB devices
heimdall-flash/eoan 1.4.1-2 arm64
tool for flashing firmware on Samsung Galaxy S devices
heimdall-flash-frontend/eoan 1.4.1-2 arm64
tool for flashing firmware on Samsung Galaxy S devices - Qt GUI
hexedit/eoan 1.4.2-5 arm64
viewer and editor in hexadecimal or ASCII for files or devices
imagination/eoan 3.4-1 arm64
DVD slide show maker
jasper/eoan 0.69 all
Configure a preinstalled ext2/3 system image
konqueror/eoan 4:19.04.3-0ubuntu1 arm64
advanced file manager, web browser and document viewer
kubuntu-restricted-extras/eoan 67 arm64
Commonly used media codecs and fonts for Kubuntu
kwordquiz/eoan 4:19.04.3-0ubuntu1 arm64
libclaw-tween1v5/eoan 1.7.4-2 arm64
C++ tweeners
libdancer-plugin-flashmessage-perl/eoan 0.314-2 all
Dancer plugin to display temporary, so called "flash messages"
libf2fs-dev/eoan 1.11.0-1.1 arm64
Core library for Flash-Friendly File System - Development files
libf2fs-format-dev/eoan 1.11.0-1.1 arm64
libf2fs-format4/eoan 1.11.0-1.1 arm64
Format library for Flash-Friendly File System
libf2fs5/eoan 1.11.0-1.1 arm64
libfaifa-dev/eoan 0.2~svn82-1build2 arm64
manage HomePlug 1.0/AV devices via ethernet frames - devel library
libfaifa0/eoan 0.2~svn82-1build2 arm64
manage HomePlug 1.0/AV devices via ethernet frames - library
libfreehep-graphicsio-swf-java/eoan 2.1.1+dfsg-3 all
FreeHEP SWF (Flash) Driver
libhal1-flash/eoan 0.3.3-3 arm64
Compatibility library to allow playback of Flash DRM content
libimage-size-perl/eoan 3.300-1 all
module for determining image sizes in several common formats
libjs-gordon/eoan 0~git20101011-3 all
Open source flash runtime written in pure javascript
libjs-mediaelement/eoan 2.15.1+dfsg-1 all
HTML5 <audio> or <video> player with Flash and Silverlight shims
libjs-soundmanager2/eoan 2.97a.20150601+dfsg2-2 all
cross-platform audio player API
libmime-lite-html-perl/eoan 1.24-3 all
Transform HTML page into MIME email
libnxt/eoan 0.3-9 arm64
utility library for talking to the LEGO Mindstorms NXT brick
libpanel-applet-dev/eoan 1:3.34.0-1ubuntu1 arm64
library for GNOME Panel applets - development files
libpanel-applet-doc/eoan 1:3.34.0-1ubuntu1 all
library for GNOME Panel applets - documentation files
libpanel-applet3/eoan 1:3.34.0-1ubuntu1 arm64
libpiano-dev/eoan 2019.02.14-1build1 arm64
library to interface with Pandora radio -- development
libpiano0/eoan 2019.02.14-1build1 arm64
library to interface with Pandora radio -- runtime files
libploticus0/eoan 2.42-4 arm64
script driven business graphics library
libquvi-0.9-0.9.3/eoan 0.9.4-0ubuntu1 arm64
library for parsing video download links (runtime libraries)
libquvi-0.9-dev/eoan 0.9.4-0ubuntu1 arm64
library for parsing video download links (development package)
libquvi-0.9-doc/eoan 0.9.4-0ubuntu1 all
library for parsing video download links (documentation package)
libquvi-scripts-0.9/eoan 0.9.20131130-1.1 all
library for parsing video download links (Lua scripts)
librocksdb-dev/eoan 5.17.2-3 arm64
persistent Key-Value Store for Flash and RAM Storage (development)
librocksdb5.17/eoan 5.17.2-3 arm64
librudecgi-dev/eoan 5.0.0-1.1ubuntu1 arm64
C++ parser library for CGI applications - development libraries
librudecgi5v5/eoan 5.0.0-1.1ubuntu1 arm64
C++ parser library for CGI applications - runtime
libstlink-dev/eoan 1.5.1+ds-1 arm64
OpenSource ST-Link tools replacement.
libstlink1/eoan 1.5.1+ds-1 arm64
libtk-tablematrix-perl/eoan 1.23-6.1build5 arm64
Table/matrix widget extension to Perl/Tk
libvdpau-va-gl1/eoan 0.4.2-1build1 arm64
VDPAU driver with OpenGL/VAAPI backend
lm4flash/eoan 3:0.1.3-1 arm64
Command-line firmware flashing tool to communicate with the Stellaris Launchpad
lpctools/eoan 1.07-1 arm64
interface to NXP LPC Microcontrollers ISP serial interface
lubuntu-restricted-extras/eoan 67 all
Commonly used media codecs and fonts for Lubuntu (Transitional)
lxpanel/eoan 0.10.0-2 arm64
LXDE panel
m16c-flash/eoan 0.1-1.1build1 arm64
Flash programmer for Renesas M16C and R8C microcontrollers
minitube/eoan 3.1-1 arm64
Native YouTube client
mnemosyne/eoan 2.6.1+ds-1 all
spaced repetition flash-card program
mongrel2-core/eoan 1.12.2-1 arm64
programming language agnostic web server (binaries)
mongrel2-run/eoan 1.12.2-1 all
mtd-utils/eoan,now 1:2.0.1-1ubuntu3 arm64 [installed,automatic]
Memory Technology Device Utilities
myrescue/eoan 0.9.8-1 arm64
rescue data from damaged disks
node-flashproxy/eoan 1.7-4 all
Pluggable transport to circumvent IP address blocking - nodejs proxy
node-policyfile/eoan 0.0.6+ds-1 all
Flash Socket Policy File Server for Node.js
nxt-firmware/eoan 1.29-20120908+dfsg-7 all
Improved firmware for LEGO Mindstorms NXT bricks
openwince-jtag/eoan 0.5.1-7build1 arm64
allows programming jtag capable devices such as CPUs or FPGAs
parley/eoan 4:19.04.3-0ubuntu1 arm64
vocabulary trainer
phnxdeco/eoan 0.33-3build1 arm64
Decompress flashfiles equipped with a PHOENIX BIOS
pianobar/eoan 2019.02.14-1build1 arm64
console based player for Pandora radio
pictor-unload/eoan 2.38-0ubuntu2 all
tool for unloading and renaming pictures from flash media
pithos/eoan 1.1.2-1 all
Pandora Radio client for the GNOME desktop
ploticus/eoan 2.42-4 arm64
script driven business graphics package
policykit-1-gnome/eoan 0.105-7ubuntu2 arm64
authentication agent for PolicyKit
pt-websocket/eoan 0.2-8 arm64
WebSocket pluggable transport - server
pxfw/eoan 0.7.2-4.1 arm64
Plextor firmware updater
python-olefile/eoan 0.46-1 all
Python module to read/write MS OLE2 files
python3-mbed-host-tests/eoan 1.4.4-1 all
module and utilities to flash, reset and test Mbed Enabled devices
python3-mbed-host-tests-doc/eoan 1.4.4-1 all
module and utilities to flash, reset and test Mbed Enabled devices (docs)
python3-olefile/eoan,now 0.46-1 all [installed,automatic]
python3-pyocd/eoan 0.13.1+dfsg-1 all
ARM Cortex-M programming tools (Python3)
python3-streamlink/eoan 1.1.1+dfsg-1 all
Python module for extracting video streams from various websites
python3-streamlink-doc/eoan 1.1.1+dfsg-1 all
CLI for extracting video streams from various websites (documentation)
python3-uflash/eoan 1.2.4+dfsg-1 all
module and utility for flashing the BBC micro:bit
python3-uflash-doc/eoan 1.2.4+dfsg-1 all
module and utility for flashing the BBC micro:bit (documentation)
python3-websockify/eoan 0.8.0+dfsg1-16ubuntu1 arm64
WebSockets support for any application/server - Python 3
qemu-skiboot/eoan 6.5-1 all
OpenPower firmware component
quvi/eoan 0.9.4-1.1build1 arm64
command line program to extract video download links
r-cran-animation/eoan 2.6+dfsg-1 all
GNU R gallery of animations and utilities to create animations
r-cran-fastcluster/eoan 1.1.25-2 arm64
Fast hierarchical clustering routines for GNU R
r-cran-flashclust/eoan 1.01-2-2 arm64
Implementation of optimal hierarchical clustering
r-cran-googlevis/eoan 0.6.4+dfsg-1 all
GNU R Interface to Google Charts
reminiscence/eoan 0.2.1-2build1 arm64
free implementation of Flashback game engine
rhythmbox-ampache/eoan 0.11.1+svn43-1 all
play audio streams from an Ampache server
rkflashtool/eoan 0~20160324-2 arm64
Tools for flashing Rockchip devices
rocksdb-tools/eoan 5.17.2-3 arm64
persistent Key-Value Store for Flash and RAM Storage (tools)
ruby-rack-flash3/eoan 1.0.5-2 all
Flash hash for Ruby Rack applications
ruby-rails-assets-fine-uploader/eoan 5.13.0-1 all
Official bower build for FineUploader/fine-uploader
ruby-rails-assets-jquery-fullscreen-plugin/eoan 0.5.0+dfsg-1 all
jQuery fullscreen plugin for rails applications
ruby-responders/eoan 2.4.0-3 all
set of Rails responders to dry up your application
seabios/eoan 1.12.0-1 all
Legacy BIOS implementation
stlink-gui/eoan 1.5.1+ds-1 arm64
stlink-tools/eoan 1.5.1+ds-1 arm64
stm32flash/eoan 0.5-1build1 arm64
STM32 chip flashing utility using a serial bootloader
CLI for extracting video streams from various websites to a video player
swfmill/eoan 0.3.6-1 arm64
xml2swf and swf2xml processor
texlive-latex-extra/eoan 2019.20190710-1 all
TeX Live: LaTeX additional packages
tiemu/eoan 3.04~git20110801-nogdb+dfsg1-2 arm64
Texas Instruments calculators emulator (without GDB)
tilem/eoan 2.0-3 arm64
GTK+ TI Z80 calculator emulator
tilem-data/eoan 2.0-3 all
GTK+ TI Z80 calculator emulator (data files)
tilp2/eoan 1.18-3 arm64
Texas Instruments hand-helds <-> PC communication program for X
tk-table/eoan 2.10-3 arm64
Table extension for Tcl/Tk
u-boot-menu/eoan 4 all
u-boot menu update
u3-tool/eoan 0.3-3 arm64
tool for controlling the special features of a U3 USB flash disk
Commonly used media codecs and fonts for Ubuntu
udiskie/eoan 1.7.7-2 all
automounter for removable media for Python
uefitool/eoan 0.26.0-2 arm64
UEFI firmware image viewer and editor
uefitool-cli/eoan 0.26.0-2 arm64
UEFI firmware image viewer and editor - CLI version
uget/eoan 2.2.2-1 arm64
easy-to-use download manager written in GTK+
unburden-home-dir/eoan 0.4.1.1 all
Remove or move cache files automatically from user's home
unmass/eoan 0.9-4 arm64
Extract game archive files
urjtag/eoan 0.10+r2007-1.2build2 arm64
JTAG programmer for various flash parts and boards
usb-modeswitch/eoan,now 2.5.2+repack0-2ubuntu1 arm64 [installed,automatic]
mode switching tool for controlling "flip flop" USB devices
usb-modeswitch-data/eoan,now 20170806-2 all [installed,automatic]
mode switching data for usb-modeswitch
videoporama/eoan 0.8.1-0ubuntu7 all
Make and export image slideshows
wipe/eoan 0.24-4 arm64
secure file deletion
xc3sprog/eoan 0+svn795+dfsg-1 arm64
JTAG flashing tool for FPGAs, CPLDs and EEPROMs
xmms2-plugin-flv/eoan 0.8+dfsg-18.2 arm64
XMMS2 - Flash Video plug-in
yamdi/eoan 1.4-3 arm64
utility for adding metadata to flash video files
I was looking at the Ubuntu Forums page referenced in the first link previously; it was shortly thereafter that I had to start from scratch... It's old (2016) and no longer applies. There's a newer (2018) version, but that's out of date as well. My concern is the dpkg statement: What would the net effect of that be long-term? Following the test on the Debian Multiarch Wiki, dpkg --print-foreign-architectures does not return anything. I'm guessing that means dpkg is multiarch aware, but I would have to add the architecture to get feedback. But I can't afford to start over at this point so I'm holding off till I know more.
Yeah, I'm far out of my comfort zone too...graf_eberstein wrote: Please note that although I know my way around *nix to some extent, this is now deep in unfamiliar territory for me...
Addendum to my last posting:
browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb
libavcodec-extra57_3.4.2-2_arm64.deb
libavcodec57_3.4.2-2_arm64.deb
libavutil55_3.4.2-2_arm64.deb
libevent-pthreads-2.1-6_2.1.8-stable-4build1_arm64.debCode: Select all
browser-plugin-freshplayer-pepperflash_0.3.5-1ubuntu7_arm64.debI have no idea.graf_eberstein wrote: ↑Wed Apr 29, 2020 8:37 pm[I was able to locate the following collection of .deb files earlier today, based on yet something else I found online:Except for libavcodec-extra* (not installed) and libevent-pthreads (installed), the above appear to be newer releases of those packages. Would installing libavcodec-extra58 suffice, or would I still have to install the older releases? This is the type of thing that puts me waaaaaaaaaaaaaaaaaay out of my element...Code: Select all
browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb libavcodec-extra57_3.4.2-2_arm64.deb libavcodec57_3.4.2-2_arm64.deb libavutil55_3.4.2-2_arm64.deb libevent-pthreads-2.1-6_2.1.8-stable-4build1_arm64.deb
sudo dpkg -i browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.debRe. Raspbian:Botspot wrote: ↑Wed Apr 29, 2020 8:30 pmSo I suggest we work on the top one: Why do you insist Raspbian is not an option?
- Use Raspbian. Chromium + flash is included, and with the new raspbian-nspawn-64 package, you can run 64-bit apps if you so desire.
- Uninstall chromium:arm64 from your ubuntu, and afterward try to install chromium:armhf. All that to make use of an armhf flash .so file.
- Similar to the above option: Run chromium:armhf in a Raspbian VM inside your Ubuntu to run flash. Maybe use the systemd-nspawn technique my Pi Power Tools uses to boot.
- Find some other way to do it which we haven't considered yet.
Botspot wrote: ↑Wed Apr 29, 2020 8:53 pmHere's a copy-paste from the TTY:graf_eberstein wrote: ↑Wed Apr 29, 2020 8:37 pmWhat happens when you run this?Code: Select all
sudo dpkg -i browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.debCode: Select all
$ sudo dpkg -i browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb Selecting previously unselected package browser-plugin-freshplayer-pepperflash. (Reading database ... 263690 files and directories currently installed.) Preparing to unpack browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb ... Unpacking browser-plugin-freshplayer-pepperflash (0.3.4-3) ... dpkg: dependency problems prevent configuration of browser-plugin-freshplayer-pepperflash: browser-plugin-freshplayer-pepperflash depends on libavcodec-ffmpeg56 (>= 7:2.4) | libavcodec-ffmpeg-extra56 (>= 7:2.4); however: Package libavcodec-ffmpeg56 is not installed. Package libavcodec-ffmpeg-extra56 is not installed. browser-plugin-freshplayer-pepperflash depends on libavutil-ffmpeg54 (>= 7:2.4); however: Package libavutil-ffmpeg54 is not installed. browser-plugin-freshplayer-pepperflash depends on libevent-2.0-5 (>= 2.0.10-stable); however: Package libevent-2.0-5 is not installed. browser-plugin-freshplayer-pepperflash depends on libevent-pthreads-2.0-5 (>= 2.0.10-stable); however: Package libevent-pthreads-2.0-5 is not installed. browser-plugin-freshplayer-pepperflash depends on libssl1.0.0 (>= 1.0.0); however: Package libssl1.0.0 is not installed. browser-plugin-freshplayer-pepperflash depends on libva-x11-1 (>= 1.0.3); however: Package libva-x11-1 is not installed. browser-plugin-freshplayer-pepperflash depends on libva1 (>= 1.2.0); however: Package libva1 is not installed. dpkg: error processing package browser-plugin-freshplayer-pepperflash (--install): dependency problems - leaving unconfigured Errors were encountered while processing: browser-plugin-freshplayer-pepperflash
Yeah I don't think dpkg auto-installs dependencies. Maybe apt does, but IDK.graf_eberstein wrote: ↑Wed Apr 29, 2020 9:55 pmCode: Select all
sudo apt install browser-plugin-freshplayer-pepperflash_0.3.4-3_arm64.deb
