RPIZW
Raspberry pi4 5G found but won’t connect
Sun Apr 26, 2020 9:26 pm
Hi all,
I received my Pi4 today, installed raspbian on it and couldn’t connect my 5G wifi even though the SSID appears and have a great signal.
It asks for password again and again but won’t connect. Of course I did checked the password that is correct and can connect other devices to it, except Pi4
I tried to change to lower channels , higher channels, and changed the control channels, almost checked any possible options, but the same results.
I also installed some other OS and even used different MicroSD card just to be sure.
2.4Ghz works well.
Did anyone had this problem? Or it’s a hardware issue?
RPIZW
Re: Raspberry pi4 5G found but won’t connect
Mon Apr 27, 2020 10:36 am
looks like I'm the first with this issue.
any advice? should I just try to replace the hardware or there's some troubleshoot you can suggest?
