Mega_Squid
Audio through HDMI
Fri Dec 28, 2012 1:54 am
Hi all I am a noob obviously and I'm having trouble getting audio to play through the HDMI instead of the audio jack. How do I change it so it will play through the HDMI on my TV? I like to use mocp in order to play music files off my thumb drive, but it will only play through the audio jack and the sound quality is horrible.
Ps: I did use the search bar just haven't been able to find anything :/ If i missed a topic could you please direct me to it?
Liuqahs15
Re: Audio through HDMI
Fri Dec 28, 2012 6:03 am
I'm in the same boat my friend : (
Unfortunately, as of now it seems that most people (even the foundation) advise that you do a search through google rather than the site search bar. Here's the only topic I've found to be useful:
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=5062
But just barely, unfortunately. I've gotten audio through analog on my headphones, but I can't hear anything through HDMI no matter what monitor I plug it into. I'll come back with an update if I find a solution
malakai
Fri Dec 28, 2012 6:32 am
Here's some steps
How To – Configure Sound
edit config.txt
sudo nano /boot/config.txt
Uncomment # hdmi_drive=2
# Force the monitor to HDMI mode so that sound will be sent over HDMI cable
hdmi_drive=2
The rest is just an fyi
To get sound out the headphone jack type:
sudo modprobe snd_bcm2835
sudo amixer cset numid=3 1
To get sound out the HDMI
sudo amixer cset numid=3 0
Trouble with omxplayer
set the -o output for 3.5 audio jack
omxplayer -o local
set the -o output for hdmi
omxplayer -o hdmi
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
Jim JKla
Fri Dec 28, 2012 7:08 am
I am going to test and rework these instructions for Noobs using the wiki if thats ok with you malakai ;)
Mega_Squid
Fri Dec 28, 2012 7:36 am
malakai wrote:Here's some steps
edit config.txt
hdmi_drive=2
omxplayer -o local
omxplayer -o hdmi
Thanks a ton for the quick responses, I tried all of those thing and haven't had any luck. I will make sure to post the solution when i find it :)
Mega_Squid
Fri Dec 28, 2012 7:37 am
Liuqahs15 wrote:I'm in the same boat my friend : (
I'm looking into that link right now it seems promising.
Liuqahs15
Fri Dec 28, 2012 3:34 pm
If you've already tried the above instructions, you'll have little luck. The only information aside from what's been already said about config.txt is that you should post your edid dump by typing "tvservice -d [file name here]" and that'll dump some info about your tv. When I do that, though, the file is just garbage.
Apparently, there may be some required parser for the data that is output, but I really don't know. I wouldn't know how to install it or (worst of all) compile it if necessary. I'm starting to think the pi might be a lot to take on for an actual beginner who knows nothing about linux or hardware.
Fri Dec 28, 2012 4:09 pm
Liuqahs15 wrote: Apparently, there may be some required parser for the data that is output, but I really don't know. I wouldn't know how to install it or (worst of all) compile it if necessary. I'm starting to think the pi might be a lot to take on for an actual beginner who knows nothing about linux or hardware.
There are certainly a few areas that need some more extensive documentation - that will come with time. There's lots of people out there who have got all this stuff working, so it's not impossible - keep at it - you are learning all the time!!
Mega_Squid
Fri Jan 04, 2013 9:56 pm
Thanks for the encouragement, but did this topic ever actually get solved? Has anyone had any luck?
jfornango
Contact: Yahoo Messenger
Sat Jan 12, 2013 5:38 am
If you read the thread referenced up top (http://www.raspberrypi.org/phpBB3/viewtopic.php?t=5062), you'll note that it is mostly fixed.
I say mostly because you need to get some info from your system and, if your TV has a mode that is compatible, you'll have to adjust your config.txt.
I supposed the next step is to get someone to script a quick hdmi_fix script that will do the work for us.
If I can't find anything, give me a few days to get my RPi set up (just got it two days ago), and I'll see what I can do.
I'm only wearing black until they find something darker.
