wlefferd
Should there be some led on when I power up?
Thu Apr 23, 2020 4:59 pm
My brand new just opened up pi zero looks DOA. I think there should be some led lights when I apply power. I have used multiple power supplies but I get nothing. This is my first zero and before I send it back I want to make sure there should be some led indicator.
drgeoff
Re: Should there be some led on when I power up?
Thu Apr 23, 2020 6:15 pm
The single LED on a Zero or ZeroW is a combined power and SD card activity indicator.
Have you put a micro-SD containing a bootable OS in the card slot?
If still in trouble read the "not booting" sticky before posting again.
wlefferd
Fri Apr 24, 2020 6:12 pm
Is the version of Raspbian for the zero different than for RP 3? Should you be able to use the same memory card with the most update version or is their a difference?
B.Goode
Fri Apr 24, 2020 6:27 pm
No, yes, and no. In that order.
HawaiianPi
Fri Apr 24, 2020 7:01 pm
The latest version of Raspbian will run on all models of Raspberry Pi.
