Zordey
How to connect with RPI from other network?
Thu Apr 23, 2020 4:55 pm
Hello!
The RPI is setup on my local network and everything is working. How I can connect with device using smartfon and VNC?
drgeoff
Re: How to connect with RPI from other network?
Thu Apr 23, 2020 6:20 pm
Hello!
Can the phone connect by Wi-Fi to the same network the RPi is on? Or must the phone use the cellular network?
B.Goode
Thu Apr 23, 2020 6:21 pm
Welcome to the Raspberry Pi forums.
Hello!
The Raspberry Pi organisation has documentation for most common uses of their products.
In this case - https://www.raspberrypi.org/documentati ... /README.md
Zordey
Thu Apr 23, 2020 6:49 pm
Hello!
No Wi-Fi only cellular network :)
drgeoff
Thu Apr 23, 2020 7:44 pm
Hello!
Either:
1. You will need to know the public address of the NAT router between the internet and the network the RPi is on. You will need to forward port(s) on that router. None of it is RPi specific.
or
2. Use the "cloud" method as per the instructions on the page linked to by B.Goode.
Zordey
Sun Apr 26, 2020 7:40 pm
I used NO-IP but its a little exepnsive method.
