Is the block diagram an accurate representation of the BCM2711 or are there some errors in the diagram?
Why ? viewtopic.php?t=244416#p1510284lingon wrote: ↑Wed Apr 22, 2020 2:22 pmThanks for pointing out the thread from last November. I had not read it previously. I'm curious to know if the SD-interface on the Raspberry Pi 4 can run at 104 MHz or not. If not then I'm curious to know where the hardware limitation is that restricts the clock frequency to 50 MHz.
How?
