Ever since I bought my raspberry pi 4B, i noticed an issue with the screen being too big to fit my tv and ends up being cut off from the edges (this was not an issue with my 3B+). However, on raspbian, adding “dtoverlay=vc4-fkms-v3d” to config.txt did the trick.
But, with Ubuntu 20.04 LTS, doing the same didn’t seem to work at all. Same goes with adding “disable_overscan=1” to the usercfg.txt (same outcome using config.txt even though for ubuntu it clearly says to not modify config.txt and use usercfg.txt instead).
I tried everything I could possibly find online to no avail. And the Ubuntu community don’t seem to respond. So I figured you guys would know better about the raspberry pis anyway.
Here’s my current setup:
Raspberry Pi 4B 4GB RAM (first version)
64GB SANDISK A2 SD Card
Ubuntu 20.04 LTS (64-bit ARM) from here: (http://cdimage.ubuntu.com/ubuntu-server ... EADER.html)
1920x1080 TV (with no setting for overscan... i tried every one of its few settings and none have anything to do with overscan... i even tried all the hdmi ports)
I’m looking forward to your help
