mmkw43
Weather forecast with python
Thu Apr 16, 2020 1:16 pm
A novice on this -- looked into openweathermap and I can see what that's all about. Unfortunately there isn't an easy way to have an actual forecast with rain percentage etc. So stupid question maybe but is there any way I can have a forecast in a python application? I was wondering if these weather widgets could somehow be embedded in the program and then be updated a couple of times an hour online. I'm trying to avoid being connected to the internet as a requirement -- just connect a couple of times an hour to update. Not sure if those widgets would work.
Just push me in the right direction (if there is one). :) --THANKS
B.Goode
Re: Weather forecast with python
Thu Apr 16, 2020 2:31 pm
It might not be the right direction for you, but this might be relevant -
https://bigl.es/tooling-tuesday-wttr/
mmkw43
Thu Apr 16, 2020 5:40 pm
Wow, pretty cool. I'll have to play with that. Going to need something I can depend on but this looks very interesting. Thanks a lot.
peppy.player
Thu Apr 16, 2020 9:13 pm
You can use Yahoo!Weather web service directly without any wrappers:
https://developer.yahoo.com/weather/
I used it for the Weather screensaver in the Peppy Player:
https://github.com/project-owner/Peppy.doc/wiki/Weather
Good luck!
mmkw43
Thu Apr 16, 2020 11:10 pm
Ok. I did try openweather but it has no actual (detailed) forecast. It just gives true or false answers for a 3 day forecast like rain? clouds? etc.
Do you know if the yahoo api has a forecast? (Like % chance of rain etc)
mmkw43
Thu Apr 16, 2020 11:11 pm
Oh Ok -- just saw your peppy player. THAT is what I want !
I may be back with questions. Thanks.
cyber7
Thu Nov 05, 2020 1:09 pm
PEPPY is just AWESOME!
joelostinspace
Thu Nov 05, 2020 10:04 pm
there's a couple ways to use owm, I use folium webbrowser and os to make calls to the api and pull information out of a json file and an other is to use the python wrapper pyowm.
here's a folium example off there website: https://code-maven.com/openweathermap-api-using-python
and here's wrapper example: https://github.com/csparpa/pyowm
there really isn't a need to make multiple calls an hour the have a One Call that has the current weather and 48 hour forecast and a 7 day forecast
To travel is to discover that everyone is wrong about other countries.
--- Aldous Huxley
Return to “Python”
