Fri Apr 17, 2020 2:32 pm
Thanks for the reply. I tried to modify firmware/config.txt, usrconfig.txt and also the config.txt at same location when havins raspi-config installed in Ubuntu Mate. Always the same result...
After modifiying the desired configuration and reboot, the RPI4 enter into a loop trying to boot: the color image blinks, and immediately turns off. Then boot again, a blink of the colored image, turn off... and so on.
The configuration works perfectly in Raspbian, and it looks like:
#i2c, i2s, spi... are deactivated
dtoverlay=i2c-gpio,bus=3,i2c_gpio_sda=23,i2c_gpio_scl=24,i2c_gpio_delay_us=2
# DPI Video Setup
dtoverlay=dpi18
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
framebuffer_width=854
framebuffer_height=480
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=458773
hdmi_timings=854 0 14 4 12 480 0 2 3 9 0 0 0 60 0 32000000 3
