Pi 4, 4GB, Raspbian 64 bit (nspawn):
$ uname -a
Linux debian-buster-64 4.19.97-v8+ #1294 SMP PREEMPT Thu Jan 30 13:27:08 GMT 2020 aarch64 GNU/Linux
pi@debian-buster-64:~/stream $ free -h
total used free shared buff/cache available
Mem: 3.7Gi 119Mi 3.1Gi 8.0Mi 503Mi 3.5Gi
Swap: 99Mi 0B 99Mi
pi@debian-buster-64:~/stream $ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/aarch64-linux-gnu/8/lto-wrapper
Target: aarch64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 8.3.0-6' --with-bugurl=file:///usr/share/doc/gcc-8/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-gcc-major-version-only --program-suffix=-8 --program-prefix=aarch64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libquadmath --disable-libquadmath-support --enable-plugin --enable-default-pie --with-system-zlib --disable-libphobos --enable-multiarch --enable-fix-cortex-a53-843419 --disable-werror --enable-checking=release --build=aarch64-linux-gnu --host=aarch64-linux-gnu --target=aarch64-linux-gnu
Thread model: posix
gcc version 8.3.0 (Debian 8.3.0-6)
pi@debian-buster-64:~/stream $ gcc -Wall -O3 -fopenmp -o streamomp.10M stream.c
stream.c: In function ‘mysecond’:
stream.c:424:13: warning: variable ‘i’ set but not used [-Wunused-but-set-variable]
int i;
pi@debian-buster-64:~/stream $ ./run.sh ; ./run.sh ; ./run.sh
Running on CPUs 0 ...
STREAM version $Revision: 5.10 $
This system uses 8 bytes per array element.
Array size = 10000000 (elements), Offset = 0 (elements)
Memory per array = 76.3 MiB (= 0.1 GiB).
Total memory required = 228.9 MiB (= 0.2 GiB).
Each kernel will be executed 10 times.
The *best* time for each kernel (excluding the first iteration)
will be used to compute the reported bandwidth.
Number of Threads requested = 1
Number of Threads counted = 1
Your clock granularity/precision appears to be 1 microseconds.
Each test below will take on the order of 59629 microseconds.
(= 59629 clock ticks)
Increase the size of the arrays if this shows that
you are not getting at least 20 clock ticks per test.
WARNING -- The above is only a rough guideline.
For best results, please be sure you know the
precision of your system timer.
Function Best Rate MB/s Avg time Min time Max time
Copy: 5426.1 0.029606 0.029487 0.030237
Scale: 5506.8 0.029117 0.029055 0.029254
Add: 4736.1 0.050715 0.050675 0.050739
Triad: 4694.3 0.051198 0.051126 0.051331
Solution Validates: avg error less than 1.000000e-13 on all three arrays
Running on CPUs 0,1 ...
Number of Threads requested = 2
Number of Threads counted = 2
Each test below will take on the order of 62619 microseconds.
(= 62619 clock ticks)
Copy: 4219.1 0.039184 0.037923 0.040375
Scale: 3711.7 0.043809 0.043107 0.044489
Add: 3908.9 0.061444 0.061398 0.061506
Triad: 3961.5 0.060630 0.060583 0.060691
Running on CPUs 0,1,2 ...
Number of Threads requested = 3
Number of Threads counted = 3
Each test below will take on the order of 60485 microseconds.
(= 60485 clock ticks)
Copy: 3540.1 0.045948 0.045197 0.047625
Scale: 3473.5 0.046372 0.046063 0.046612
Add: 3268.0 0.073785 0.073440 0.074125
Triad: 3437.7 0.070172 0.069815 0.070442
Running on CPUs 0,1,2,3 ...
Number of Threads requested = 4
Number of Threads counted = 4
Each test below will take on the order of 59525 microseconds.
(= 59525 clock ticks)
Copy: 3451.6 0.046944 0.046355 0.047843
Scale: 3718.8 0.044152 0.043025 0.045274
Add: 3291.4 0.073877 0.072917 0.075240
Triad: 3253.0 0.074533 0.073779 0.075255
Each test below will take on the order of 59698 microseconds.
(= 59698 clock ticks)
Copy: 5417.5 0.029607 0.029534 0.029730
Scale: 5504.7 0.029112 0.029066 0.029197
Add: 4725.9 0.050832 0.050784 0.050911
Triad: 4679.5 0.051316 0.051288 0.051430
Each test below will take on the order of 62061 microseconds.
(= 62061 clock ticks)
Copy: 4147.2 0.039571 0.038580 0.041167
Scale: 3716.6 0.043713 0.043050 0.044059
Add: 3895.3 0.061698 0.061613 0.061753
Triad: 3936.0 0.061027 0.060975 0.061079
Each test below will take on the order of 60931 microseconds.
(= 60931 clock ticks)
Copy: 3362.8 0.049671 0.047580 0.052043
Scale: 3370.5 0.047724 0.047471 0.048038
Add: 3143.8 0.076699 0.076341 0.077099
Triad: 3333.7 0.072607 0.071992 0.073065
Each test below will take on the order of 61228 microseconds.
(= 61228 clock ticks)
Copy: 3331.0 0.048920 0.048033 0.049906
Scale: 3645.6 0.044595 0.043888 0.045386
Add: 3213.6 0.075035 0.074682 0.075698
Triad: 3204.3 0.075369 0.074900 0.076134
Copy: 5413.8 0.029589 0.029554 0.029631
Scale: 5510.8 0.029088 0.029034 0.029151
Add: 4728.4 0.050821 0.050757 0.050915
Triad: 4683.4 0.051375 0.051245 0.052019
Each test below will take on the order of 62449 microseconds.
(= 62449 clock ticks)
Copy: 3856.4 0.042674 0.041490 0.044648
Scale: 3708.2 0.043976 0.043148 0.044730
Add: 3843.2 0.062549 0.062448 0.062685
Triad: 3853.2 0.062347 0.062286 0.062415
Each test below will take on the order of 60369 microseconds.
(= 60369 clock ticks)
Copy: 3438.7 0.048310 0.046529 0.050204
Scale: 3444.9 0.046806 0.046445 0.047192
Add: 3135.5 0.076741 0.076542 0.077033
Triad: 3322.3 0.072500 0.072239 0.072907
Each test below will take on the order of 60132 microseconds.
(= 60132 clock ticks)
Copy: 3558.9 0.047131 0.044958 0.050026
Scale: 3521.2 0.046606 0.045439 0.047983
Add: 3447.1 0.072796 0.069624 0.076257
Triad: 3439.9 0.072690 0.069769 0.074759
