hackedmacbook111
Contact: YouTube
Re: How to setup Minecraft 1.15.2 on Pi4
Sat May 23, 2020 11:17 pm
I started the installation process of 1.15.2 without changeing to gldrivers is it OK to continue installing minecraft 1.15.2 I just installed 1.15.2 from launcher and it came up with error code should I continue and turn on gl driver later
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 11:20 pm
galactic649
Sun May 24, 2020 5:32 pm
Its working, but it won't let me get into servers because of an "invalid session". Does anyone know why?
hackedmacbook111
Contact: YouTube
Sun May 24, 2020 5:50 pm
Are you using an alt by chance that you didn't buy from mojang
If so your alt might have expired and raspberry pi still allows you to use minecraft but only in single player
hackedmacbook111
Contact: YouTube
Wed May 27, 2020 1:32 am
I successfully installed minecraft 1.15.2 on ubuntu 20.04 but I got this error when attempting to do command to run
./runMC1_15_2_OptifineG1.sh
I think that if it were able to run in ubuntu it would run better especially the arm64 version of ubuntu
The Error code I got was ./runMC1_15_2_OptifineG1.sh: 46: /opt/jdk/jdk1.8.0_241/bin/java: not found
When I go to that dirrctory everything looks the same as the same folder but on the raspbian buster sd card and I don't get this error in raspbian
I want to test the performance of minecraft 1.15.2 on ubuntu on the raspberry pi 4 B 4GB
hackedmacbook111
Contact: YouTube
Wed May 27, 2020 1:33 am
If you haven't already please start getting ready to make the upcoming 1.16 version compatible with raspberry pi 4
rpiMike
Wed May 27, 2020 6:15 am
This script installs 32 bit lwjgl3 libraries and 32 bit java, you would need 64 bit versions.
rpiMike
Wed May 27, 2020 6:16 am
Not until versions of Optifine are available.
hackedmacbook111
Contact: YouTube
Wed May 27, 2020 5:24 pm
Why is Optifine needed to run minecraft
I was able to run minecraft 1.8.9 on an overclocked pi2 once and it didn't have optifine
I will retry the minecraft tutorial but on a 32bit version of ubuntu instead
I originally used 64bit version of ubuntu
rpiMike
Wed May 27, 2020 5:34 pm
Because Optifine improves performance and makes the game more playable.
hackedmacbook111
Contact: YouTube
Wed May 27, 2020 5:41 pm
I think you should update the optifine the current version as of this post is pre18G1
the version in the tutorial is pre13
It might be worth updateing it
hackedmacbook111
Contact: YouTube
Wed May 27, 2020 5:55 pm
I am redoing tutorial on raspbian buster but instead of optifine 1.15.2 pre13 I am using pre18
seems that it can be updated
I will post new command to install optifine pre18
Minecraft loads with the new updated optifine
Better performance with pre18
hackedmacbook111
Contact: YouTube
Wed May 27, 2020 6:33 pm
Disclaimer this is not a new tutorial to install minecraft 1.15.2
This is a way to update the optifine from the original tutorial
Download Optifine pre18 G1 jar file
 cd~/Minecraft && wget https://optifine.net/downloadx?f=preview_OptiFine_1.15.2_HD_U_G1_pre18.jar&x=7bb2194409aec2fed77fb030214c6be7
Run Optifine
cd ~/Minecraft && /opt/jdk/jdk1.8.0_241/bin/java -jar preview_OptiFine_1.15.2_HD_U_G1_pre18.jar
Run Minecraft Launcher
cd ~/Minecraft && /opt/jdk/jdk1.8.0_241/bin/java -jar launcher.jar
If you aren't already select Optifine profile click play and wait until launcher crashes
Now run Minecraft from terminal window
cd ~/Minecraft
Now you have updated your optifine performance is just slightly better
Updateing the Optifine was tested in Raspbian Buster Full desktop on raspberry pi 4 4GB model
For those who had game crash it runs smoother than before
There is still a problem with game freezing then going back to normal
Updating Optifine to pre18 from pre13 makes it so the game freezes for less time
Try the newly updated optifine for better performance on minecraft 1.15.2 for raspberry pi 4 2GB and 4GB models
Jurosik5000
Thu May 28, 2020 12:47 pm
Hey i have a question is it specific to minecraft 1.15.2? if not tell me please how can i edit the .sh file to run other versions too. Thanks :D
Aliensnipemaster
Fri May 29, 2020 3:58 pm
This isn't compatible with Raspberry Pi OS (64bit) beta
Needed is java for arm64
Then I can retest it
Still works with arm32 raspbian
bunklung
Sat May 30, 2020 3:03 pm
Thanks for this. I was able to install this to the same directory and crazy enough I can run both versions 1.12.2 or 1.15.2.
The main hangup for me is the performance is much worse. I would typically get about 50-60 fps in 1.12.2, not I get about half that: 25-30 :(
I assume that there are few things going on here as 1.15.2 has a bunch more features that may be complicating rendering and OptiFine might be less efficient, preview_OptiFine_1.15.2_HD_U_G1_pre13
I do see pre18 in this thread. I am curious if others have tried that version and what kind of performance they get.
bunklung
Sat May 30, 2020 3:58 pm
Your download location is broken (cd~ needs a space) and your URL is user/time specific. You need to modify the runMC script to change the OptiFine to pre18 from pre13:
Use this URL to manually place the file in the ~/Minecraft folder:
https://optifine.net/adloadx?f=preview_ ... _pre18.jar
Use this command to modify the script to point to pre18:
cd ~/Minecraft && sed 's/pre13/pre18/g' runMC1_15_2_OptifineG1.sh > runMC1_15_2_OptifineG1pre18.sh
The you launch it with:
cd ~/Minecraft
./runMC1_15_2_OptifineG1pre18.sh
I have not noticed any changes to performance with pre18 over pre13.
Run Optifine
cd ~/Minecraft
RockSaveWorld
Mon Jun 01, 2020 2:50 pm
periodically when loading the game a black screen but there is sound
«If you look at what you have in life, you’ll always have more. If you look at what you don’t have in life, you’ll never have enough». (с)
rpiMike
Mon Jun 01, 2020 2:54 pm
Give us a clue? Any other info?
Which Pi? Which OS? Fully updated? Nothing else running? Connected to HDMI monitor? Resolution? Which optifine?
Pokemonbulbasaur
Mon Jun 01, 2020 10:38 pm
Was able to run it while streaming to discord and run it with minimal lag
Tutorial is incompatible with my modded ubuntu mate that is modded to look like linux mint 19.3
SupaTailsBros
Wed Jun 03, 2020 5:55 pm
Hello! Just installed the Pre 19, and I have noticed that 18 and 19 seem to have no sound. No idea if this is because of the Pi, or the version, even tried re installing, but it didn't make a sound. Also, whenever I try and join a server, I get a message, saying I 'Disconnected'
Much help appreciated!
rpiMike
Wed Jun 03, 2020 6:52 pm
What server are you trying to connect to? Are you using your own valid Minecraft account?
SupaTailsBros
Thu Jun 04, 2020 8:35 am
I am trying to join Hypixel and my friends Minecraft server. I am using a Minecraft account, but I haven't paid the full version of Minecraft on it. Too much money :D
rpiMike
Thu Jun 04, 2020 9:05 am
Buy the game or don’t play. £18/$27 is a bargain for the amount of time I have spent on Minecraft. Support the gaming industry.
The_Wolf
Thu Jun 04, 2020 9:10 am
Hi thanks for your great Work.
But i have a issue when i go on an Multiplayer Server i can Play for Like 30 Seconds thane the Game and the Terminal is closing and im on my Desktop Screen i dont know why.
Sorry for my bad English
Return to “Gaming”
