dineshlama
unable to set 5 GHz band on pi 4B.
Sat Apr 11, 2020 12:14 pm
I am following https://www.raspberrypi.org/documentati ... s-point.md tutorial to set pi 4B as wireless access point with 5 Ghz band. But when i change the hw_mode=g to hw_mode=a as described in that tutorial to get 5 GHz bank wifi. and than enable and start it.with commands:
sudo systemctl unmask hostapd
sudo systemctl enable hostapd
sudo systemctl start hostapd
and than i check it info with iwconfi it don't shows that it is 5 GHz:
wlo1      IEEE 802.11  ESSID:"Pi4B"
          Mode:Managed  Frequency:2.442 GHz  Access Point: DC:A6:32:75:E5:FB
          Bit Rate=54 Mb/s   Tx-Power=15 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:on
          Link Quality=70/70  Signal level=-31 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:52   Missed beacon:0
What is the problem? Is this related to my laptops wifi card?
dickon
Re: unable to set 5 GHz band on pi 4B.
Sat Apr 11, 2020 12:42 pm
You've set it to channel 7, which it's assuming is the 2.4GHz channel 7. Pick a 5GHz channel number (likely 32 <= x <= 48 for most indoor use in most regions).
dineshlama
Sat Apr 11, 2020 2:05 pm
What channel should i give than to make the data rate higher? will any value in that range will work same?
dickon
Sat Apr 11, 2020 2:34 pm
'iw phy' will give you the list. Look for the Frequencies section of Band 2.
Return to “Advanced users”
