Sassriverrat
Ubuntu refuses to install teamviewer- headless
Thu Apr 09, 2020 2:12 am
Anyone have a good, working install code for teamviewer? I'm running Ubuntu and I've tried a few different codes and none produce a good install of teamviewer. I've tried "fixing" the code as well and it doesn't fix anything....
This was one forum that didn't work....
https://vitux.com/how-to-install-teamviewer-on-ubuntu/
kerry_s
Re: Ubuntu refuses to install teamviewer- headless
Thu Apr 09, 2020 2:24 am
that wouldn't work because that is not an armhf version.
why would you not just grab it from there site?
https://www.teamviewer.com/en/solutions ... pberry-pi/
there's is 32bit so if your using ubuntu 64, your out of luck.
Sassriverrat
Thu Apr 09, 2020 3:04 am
unfortunately I tried this one too, it's the armhf, and it didn't work either....
I guess I need arm64 compatibility...which means no go.
Return to “Ubuntu”
