Hi Guys, good day Newbie here can any one help me to figure out whats wrong with my raspberry pi 4. There is no display on my monitor. I'm using a HDMI-VGA cable and my monitor is 22'' HP compaq LA2205wg. I follow exactly on the guide provided here in this site but still I don't have display on my monitor. Can any one help me to get ride of this. I'm literally screwed up. please see my current config.txt below. I'm using a HDMI-VGA + a straight female to female HDMI to connect both cable.
## Standard Definition Video Settings
#sdtv_mode=0
#sdtv_aspect=5
#sdtv_mode=2
tvservice -m DMT
hdmi_cvt=3
## sdtv_disable_colourburst
#sdtv_disable_colourburst=1
## hdmi_safe
hdmi_safe=1
## hdmi_force_hotplug
hdmi_force_hotplug=1
## hdmi_ignore_hotplug
#hdmi_force_hotplug=1
## hdmi_drive
hdmi_drive=2
config_hdmi_boost=4
## hdmi_ignore_edid
hdmi_ignore_edid=0xa5000080
## hdmi_edid_file
hdmi_edid_file=1
## hdmi_ignore_edid_audio
#hdmi_ignore_edid_audio=1
## hdmi_force_edid_audio
hdmi_force_edid_audio=1
## hdmi_force_edid_3d
hdmi_force_edid_3d=1
hdmi_ignore_cec=1
## avoid_edid_fuzzy_match
#3avoid_edid_fuzzy_match=1
## hdmi_pixel_encoding
hdmi_pixel_encoding=1
## hdmi_group
hdmi_group=2
## hdmi_mode
hdmi_mode=58
HDMI_ASPECT_16_10=5
## config_hdmi_boost
config_hdmi_boost=10
## hdmi_ignore_cec_init
hdmi_ignore_cec_init=1
## hdmi_ignore_cec
#hdmi_ignore_cec=1
## Overscan Video Settings
disable_overscan=0
#overscan_left=24
#overscan_right=24
#overscan_top=24
#overscan_bottom=24
#disable_overscan=1
## Framebuffer Video Settings
#framebuffer_width=1280
#framebuffer_height=720
#framebuffer_width=0
#framebuffer_height=0
#framebuffer_depth=16
#framebuffer_ignore_alpha=0
## General Video Settings
#display_rotate=0
## dispmanx_offline
#dispmanx_offline=0
## decode_MPG2
#decode_MPG2=0x12345678
## decode_WVC1
#decode_WVC1=0x12345678
## Camera Settings
#start_x=0
#disable_camera_led=1
## test_mode
#test_mode=0
## Memory Settings
#disable_l2cache=0
#gpu_mem_1024=944
#disable_pvt=1
## Boot Option Settings
#disable_commandline_tags=0
#cmdline=""
#kernel=""
#kernel_address=0x00000000
#kernel_old=1
#ramfsfile=""
#ramfsaddr=0x00000000
#initramfs initramf.gz 0x00800000
#device_tree_address=0x00000000
#init_uart_baud=115200
#init_uart_clock=3000000
#init_emmc_clock=100000000
#boot_delay=0
#boot_delay_ms=0
/boot/config.txt
## avoid_safe_mode
#avoid_safe_mode=1
#disable_splash=1
#Overclocking Settings
#force_turbo=0
#initial_turbo=0
#temp_limit=85
#arm_freq=700
#arm_freq_min=700
#gpu_freq=250
#core_freq=250
#core_freq_min=250
#h264_freq=250
#isp_freq=250
#v3d_freq=250
#sdram_freq=400
#sdram_freq_min=400
#avoid_pwm_pll=1
## Voltage Settings
#current_limit_override=0x5A000020
#over_voltage=0
#over_voltage_min=0
#over_voltage_sdram=0
#over_voltage_sdram_c=0
#over_voltage_sdram_i=0
#over_voltage_sdram_p=0
## USB Power
#max_usb_current=0
## Base Device Tree Parameters
#dtparam=audio=off
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtparam=i2c_vc=off
#dtparam=i2c_arm_baudrate=100000
#dtparam=i2c_vc_baudrate=100000
#dtparam=i2s=off
#dtparam=spi=off
#dtparam=random=off
#dtparam=uart0=on
#dtparam=watchdog=off
#dtparam=act_led_trigger=mmc
#dtparam=act_led_activelow=off
#dtparam=act_led_gpio=47
#dtparam=pwr_led_trigger=mmc
#dtparam=pwr_led_activelow=off
#dtparam=pwr_led_gpio=35
## camera
#start_x=1
#gpu_mem=128
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
