jliddlejths
Syntax Error
Mon Apr 06, 2020 12:36 pm
Please could you look at the code and see what wrong with it.
It saying syntax error with elif code.
https://drive.google.com/file/d/1in-315 ... sp=sharing
pcmanbob
Re: Syntax Error
Mon Apr 06, 2020 6:41 pm
Hi.
If you want help with your code and its error then please post your code by copying and pasting it in to your post , not forgetting to use code tags
Add [code] at the top
code goes here
and [/code] at the bottom.
that way people can download it and test it, and please post the full error message as it will give use more information on which line of code has the error.
A quick look suggests your indentation is off on the elif line
DirkS
Re: Syntax Error
Mon Apr 06, 2020 6:55 pm
pcmanbob wrote: A quick look suggests your indentation is off on the elif line
Probably the line *after* elif, starting with 'if'
But there are more problems. The indentation after the 'sys.exit()' cannot be correct. It puts all the code below it inside the 'gameover' procedure, meaning it will never be reached...
pcmanbob
Re: Syntax Error
Mon Apr 06, 2020 7:11 pm
The elif is not indented to match the if statement above it either.
jliddlejths
Re: Syntax Error
Tue Apr 07, 2020 5:39 pm
Hi, Below is the full code so you can see it more clearly and test it
code][/code]
#!/usr/bin/env python
# Raspbery Snake
# Written by Gareth Halfacree for the Raspberry Pi User Guide
import pygame, sys, time, random
from pygame.locals import *
pygame.init ()
fpsclock = pygame.time.Clock ()
playSurface = pygame.display.set_mode ((640, 480))
pygame.display.set_caption ('Raspberry Snake')
redColour = pygame.Color (255, 0, 0)
blackColour = pygame.Color (0, 0, 0)
whiteColour = pygame.Color (255, 255, 255)
greyColour = pygame.Color (150, 150, 150)
snakePosition = [100,100]
snakeSegments = [[100,100],[80,100],[60,100]]
raspberryPosition = [300,300]
raspberrySpawned = 1
direction = 'right'
changeDirection = direction
def gameOver ():
gameOverFont = pygame.font.Font('freesansbold.ttf', 72)
gameOverSurf = gameOverFont.render ('Game Over', True, greyColour)
gameOverRect = gameOverSurf.get_rect()
gameOverRect.midtop = (320, 10)
playSurface.blit(gameOverSurf, gameOverRect)
pygame.display.flip ()
time.sleep (5)
pygame.quit()
sys.exit()
while True:
for event in pygame.event.get():
if event.type == QUIT:
pygame.quit()
elif event.type == KEYDOWN:
if event.key == K_RIGHT or event.key == ord ('d'):
changeDirection = 'right'
if event.key == K_LEFT or event.key == ord ('a'):
changeDirection = 'left'
if event.key == K_UP or event.key == ord ('w'):
changeDirection = 'up'
if event.key == K_DOWN or event.key == ord ('s'):
changeDirection = 'down'
if event.key == K_ESCAPE:
pygame.event.post (pygame.event.Event (QUIT))
if changeDirection == 'right' and not direction == 'left':
direction = changeDirection
if changeDirection == 'left' and not direction == 'right':
if changeDirection == 'up' and not direction == 'down':
if changeDirection == 'down' and not direction == 'up':
if direction == 'right':
snakePosition [0] += 20
if direction == 'left':
snakePosition [0] -= 20
if direction == 'up':
snakePosition [1] -= 20
if direction == 'down':
snakePosition [1] += 20
snakeSegments.insert (0,list(snakePosition))
if snakePosition [0] == raspberryPosition [0] and snakePosition [1] == raspberryPosition [1]:
raspberrySpawned = 0
else:
snakeSegments.pop()
if aspberrySpawned == 0:
x = random.randrange (1,32)
y = random.randrange (1,24)
raspberryPosition = [int (x*20), int (y*20) ]
playSurface.fill (blackColour)
for position in snakeSegments:
pygame.draw.rect (playSurface,whiteColour, Rect (position [0], position [1], 20,20))
pygame.draw.rect (playSurface,redColour,Rect (raspberryPosition [0], raspberryPosition[1], 20,20))
pygame.display.flip()
if snakePosition [0] > 620 or snakePosition[0] < 0:[0]
gameOver()
if snakePosition[1] > 460 or snakePosition[1] < 0:
for snakeBody in snakeSegments[1:]:
if snakePosition[0] == snakeBody and snakePosition[1] == snakeBody[1]:
gameOver()
fpsClock.tick(30)
Jamie
B.Goode
Re: Syntax Error
Tue Apr 07, 2020 5:53 pm
Reposted with working Code tag markup. It seems simple to me...
code][/code]
# Raspbery Snake
pygame.init ()
direction = 'right'
def gameOver ():
    time.sleep (5)
    pygame.quit()
    sys.exit()
while True:
            pygame.quit()
                                                        else:
                                                            snakeSegments.pop()
        gameOver()
        gameOver()
        fpsClock.tick(30)
Jamie
B.Goode
Re: Syntax Error
Tue Apr 07, 2020 5:57 pm
I would expect the Raspberry Pi User Guide and it's co-author Gareth Halfacree to be reliable. I therefore suspect some error has occurred in acquiring the script.
jliddlejths
Re: Syntax Error
Tue Apr 07, 2020 6:10 pm
B.Goode wrote: I would expect the Raspberry Pi User Guide and it's co-author Gareth Halfacree to be reliable. I therefore suspect some error has occurred in acquiring the script.
I now fix the code but now I get a different message:
I get the Raspberry Pi Snake come up but it is a blank screen when I close it, I get this error:
File “/home/pi/snake3.py” , line 38, in <module>
error: video system not initialized
Return to “Python”
