NoToy
6TB USB drive read only
Thu Apr 02, 2020 6:07 pm
Hi folks hopefully someone can help diagnose this problem I have.
I have an externally powered USB drive attached to my 4gb Pi4 but it is only showing up as read only. My other various drives 4tb etc are rw.
I have read the tutorial
https://pimylifeup.com/raspberry-pi-mount-usb-drive/
In the turtorial it showed how to look at mounts and the strange thing when I run cat /proc/mounts I see it seems to be mounted ro - which I assume is read only
/dev/sdb2 /media/pi/My_Bkp01 fuseblk ro,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 0 0
I have latest Pi4 update and also installed the latest ntfs by doing
sudo apt install ntfs-3g
sudo blkid shows that its and ntfs partition.
/dev/sdb2: LABEL="My_Bkp01" UUID="4A6A222A6A2212ED" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="2d81d6aa-2ff8-49e1-a709-da4ab467214a"
I would prefer to be able to have the drive auto mount when I plug in the usb cable, but it is looking like I will need to have an fstab entry.
Is there a way to have the drive auto mount, just like other smaller drives?
Regards
Tony
LTolledo
Re: 6TB USB drive read only
Thu Apr 02, 2020 9:31 pm
mount the drive in fstab using this:
UUID=4A6A222A6A2212ED   /media/pi/My_Bkp01   ntfs-3g  defaults,noatime,rw,nofail   0  0
Some people be like:
NoToy
Fri Apr 03, 2020 7:48 am
I made that change and unfortunately it hasn't helped.
I restarted the PI and believe the change has taken effect as before the owner was PI but now its root.
I did check by doing a
sudo touch test.txt
but it fails wiith an error that the file system is read only.
This all works perfectly well on 4TB and below drives (in this external case) - could there be a limit of drive size?
Thanks in advace for any help
Tony
LTolledo
Fri Apr 03, 2020 12:25 pm
my NAS is 2 x 8TB formatted as EXT4
no problem with that setup
https://www.raspberrypi.org/forums/view ... S#p1541272
trejan
Fri Apr 03, 2020 12:29 pm
Run "dmesg" and see if there are any errors when you plug in the drive.
NoToy
Fri Apr 03, 2020 4:03 pm
Here is the result of dmesg
[ 1970.963816] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1970.994531] usb 2-1: New USB device found, idVendor=174c, idProduct=55aa, bcdDevice= 1.00
[ 1970.994546] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1970.994559] usb 2-1: Product: ASMT1153e
[ 1970.994571] usb 2-1: Manufacturer: asmedia
[ 1970.994583] usb 2-1: SerialNumber: 12345678966F
[ 1971.021989] scsi host0: uas
[ 1971.026907] scsi 0:0:0:0: Direct-Access TOSHIBA HDWE160 0 PQ: 0 ANSI: 6
[ 1971.033288] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[ 1971.033304] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1971.033674] sd 0:0:0:0: [sda] Write Protect is off
[ 1971.033689] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 1971.034025] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1971.035380] sd 0:0:0:0: [sda] Optimal transfer size 33553920 bytes not a multiple of physical block size (4096 bytes)
[ 1971.100956] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1971.300797] sda: sda1 sda2
[ 1971.306576] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1973.783632] Under-voltage detected! (0x00050005)
[ 1977.943624] Voltage normalised (0x00000000)
thagrol
Fri Apr 03, 2020 6:10 pm
Try the kernel quirk to disable UAS. There's a sticky around somewhere.
LTolledo
Fri Apr 03, 2020 9:30 pm
how are you powering your setup?
am seeing undervoltage alarm in your dmesg
NoToy
Sat Apr 04, 2020 2:56 pm
Im powering my PI with my phone charger USB C Samsung Note.. The external drives have their own power supply, so ONLY the Pie (maybe keyboard and mouse) can use power. The Ethernet cable is even plugged in
NoToy
Sat Apr 04, 2020 2:57 pm
I will try this if I get nothing else, but this solution is USB host specific and as this USB device works fine for other drives, then I would prefer not to mess with it.
Regards
Tony
NoToy
Tue Apr 07, 2020 6:21 pm
Hi folks I thought I would reply even if I look stupid.
The problem was the name given to the drive had a strange last character that didn't display properly.
I put the drive in another external enclosure (10 bay) and only then noticed something strange.
I tested it in that drive bay and it worked.
Put it back in the other one, modified the mount command and its working.
Thanks for all your suggestions.
trejan
Tue Apr 07, 2020 6:31 pm
Thanks for posting the solution. Nope. Not stupid at all. That is a really strange issue. Great that you managed to fix it.
