VascoFerraz
'dhcpcd' is using deprecated sysctl (syscall)
Sun Mar 29, 2020 4:19 pm
Hi :)
Should I be worried about the following message?
ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
Thank you so much.
Vasco Ferraz
epoch1970
Re: 'dhcpcd' is using deprecated sysctl (syscall)
Sun Mar 29, 2020 4:23 pm
Not at all.
VascoFerraz
Sun Mar 29, 2020 5:13 pm
Not at all.
Thank you so much for the reply.
However, I did not have this message but when it become permanent I can't get the embedded network cards to assign IPs when using "predicable interface names".
The USB WLAN adapter, which can not use predicable names can assign IPs normally.
If I disable the "predictable interface names" both embedded network interfaces can assign IPs.
Do you think that this message might be related to this issue?
Vasco Ferraz
epoch1970
Sun Mar 29, 2020 5:54 pm
I don't really see the relation
First off I imagine dhcpcd tries to set net.ipv6.neigh.wxl12345.retrans_time if you use predictable names?
Second this tunable has to do with ARP, which dhcpcd uses, but I would be surprised if a missing tunable key alone broke dhcpcd/ipv6, without anybody ever noticing.
Third you can set these tunables yourself and see if that changes anything.
E.g. set the correct one
"sudo sysctl -w net.ipv6.neigh.wlan0.retrans_time_ms=1000" / "sudo sysctl -w net.ipv6. neigh.wxl12345.retrans_time_ms=1000"
or the old one
"sudo sysctl -w net.ipv6.neigh.wlan0.retrans_time=1000" / "sudo sysctl -w net.ipv6. neigh.wxl12345.retrans_time=1000"
VascoFerraz
Sun Mar 29, 2020 10:41 pm
Even though I have defined at the router static IPs for all the network interfaces (MAC address assigning), when using predictable names the IPs were not being assigned.
However, defining the IPs at /etc/dhcpcd.conf solved (or circumvented) the issue.
Thank you.
Vasco Ferraz
