saraz
How to solve 'Unable to locate package python3-pyside2'
Sat Mar 28, 2020 3:43 pm
Hi
I try to install pyside2 on my raspberry with this command:
sudo apt install python3-Pyside2
at the result I get:
Reading package lists... Done
Building dependency tree
E: Unable to locate package python3-Pyside2
I check my source.list and it is empty
how can I install pyside2 and solve this problem?
pcmanbob
Re: How to solve 'Unable to locate package python3-pyside2'
Sat Mar 28, 2020 3:56 pm
Hi.
Were did you get those install instructions from ?
According to the latest pyside2 project page you should use pip to install it ( note for python 3 use pip3 to install )
https://pypi.org/project/PySide2/
DirkS
Sat Mar 28, 2020 3:58 pm
sudo pip3 install PySide2
There doesn't seem to be a (meta) package for pyside2, just a load of individual packages
https://packages.debian.org/search?suit ... n3-pyside2
saraz
Sat Mar 28, 2020 4:19 pm
I test it, but I have a ]problem:
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
ERROR: Could not find a version that satisfies the requirement Pyside2 (from versions: none)
ERROR: No matching distribution found for Pyside2
pcmanbob
Sat Mar 28, 2020 4:24 pm
Further searching suggest that that pyside2 for buster has to be installed like this
Raspbian Buster has now been released and Pyside2 can be installed using:
$apt-get install python3-pyside2.qt3dcore python3-pyside2.qt3dinput python3-pyside2.qt3dlogic python3-pyside2.qt3drender python3-pyside2.qtcharts python3-pyside2.qtconcurrent python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qthelp python3-pyside2.qtlocation python3-pyside2.qtmultimedia python3-pyside2.qtmultimediawidgets python3-pyside2.qtnetwork python3-pyside2.qtopengl python3-pyside2.qtpositioning python3-pyside2.qtprintsupport python3-pyside2.qtqml python3-pyside2.qtquick python3-pyside2.qtquickwidgets python3-pyside2.qtscript python3-pyside2.qtscripttools python3-pyside2.qtsensors python3-pyside2.qtsql python3-pyside2.qtsvg python3-pyside2.qttest python3-pyside2.qttexttospeech python3-pyside2.qtuitools python3-pyside2.qtwebchannel python3-pyside2.qtwebsockets python3-pyside2.qtwidgets python3-pyside2.qtx11extras python3-pyside2.qtxml python3-pyside2.qtxmlpatterns python3-pyside2uic
and not using pip as suggested on the page I linked.
new instructions from here : https://bugreports.qt.io/browse/PYSIDE-802
saraz
Sat Mar 28, 2020 5:50 pm
Thanks a lot
It worked
Return to “Python”
