Raccooooon
Is there anyone who used this relay?
Fri Mar 27, 2020 8:11 am
I'm trying to make project that use chip resistor to cut some wire like fishing wire.
And In project, I have to use relay module.
But, I try to use other relay module not SONGLES module.
So, Is there anyone who used this relay?
It's SSR.
If so, Can you tell me how can I connect it?
(Or, Do I must use SONGLE?)
pcmanbob
Re: Is there anyone who used this relay?
Fri Mar 27, 2020 9:58 am
You will not be able to drive these relays directly from a gpio pin,
As the PDD0-103N requires at least 4V to drive the input,
the red relay has searchable no part no. so I was unable to look it up, so to be on the safe side I would not drive it directly from a gpio pin.
So you will need to use a simple transistor drive between the pi and the relays.
So the PDD0-103N is marked as being an SSR so should not need a reverse voltage protection diode, the other one is not marked such, but I suspect it is, but you might want to just check that you cant hear a mechanical contact switch when you power the relay.
Raccooooon
Tue Apr 07, 2020 8:15 am
First, Thanks for replying.
I checked It works
