RonR
Booting Raspbian on large (>2TB) USB devices : Made Easy
Fri Mar 27, 2020 2:02 am
GPT partition tables are necessary on devices whose size is over 2TB.
boot-gpt converts an MBR partition table on a USB device to a GPT partition table, as well as adding or removing a Hybrid MBR (required for direct booting on a Raspberry Pi 3), expanding the ROOT partition, enabling booting via an SD card, and enabling SSH on the next boot. boot-gpt converts any size USB device, including SD cards placed in a USB adapter (an SD card with a GPT partition table also requires a Hybrid MBR for booting).
!!! DO NOT PROCEED UNLESS YOU HAVE A RELIABLE BACKUP OF THE DEVICE BEING CONVERTED !!!
!!! INITIAL TESTING SHOULD BE PERFORMED ON A USB DEVICE CONTAINING EXPENDABLE DATA !!!
Usage syntax is:
boot-gpt /dev/sdX
boot-gpt will prompt for permission to perform the following optional functions:
1. Use Hybrid MBR (required for direct booting on a Raspberry Pi 3)
2. Expand ROOT partition to use all available space
3. Set SD card to boot the USB device
4. Enable SSH on next boot
boot-gpt.zip
(2.32 KiB) Downloaded 8 times
jameshilliard
Re: Booting Raspbian on large (>2TB) USB devices : Made Easy
Fri Mar 27, 2020 3:38 am
FYI you should probably be using sgdisk(the scriptable gdisk interface essentially) and sfdisk(the scriptable fdisk interface) rather than gdisk and fdisk for scripting.
Buildroot developer
RonR
Sat Mar 28, 2020 4:51 am
boot-gpt has been updated to make the use of a Hybrid MBR optional.
A Hybrid MBR should be used only when necessary: Hybrid MBRs: The Good, the Bad, and the So Ugly You'll Tear Your Eyes Out
Rukbat
Sun Mar 29, 2020 11:13 pm
You got that one right. :D But I like learning, so I'm going to read the whole thing (then bandage my eyes to keep the blood from dripping on my shirt).
RonR
Sun Mar 29, 2020 11:59 pm
Fortunately, Hybrid MBR's should only be needed in the case of direct booting 2TB+ drives on a Raspberry Pi 3 (booting via an SD card is a much more reliable method) and 2TB+ SD cards (that don't currently exist and will probably require a second mortgage on your home to buy one).
I hope to release updates soon to usb-boot and image-utils that also create and handle mass storage devices over 2TB using standard (non-Hybrid) GPT partition tables.
Return to “Advanced users”
