JesCads
Mono shows code as incorrect
Fri Mar 27, 2020 12:09 am
I have the problem that I cannot write working code in mono. The IDE always shows me an error. Even the default "Hello World" program is displayed as false.
Here is a picture of the "wrong" code: klick
To me it looks like some libraries are missing. But all of my software is up to date and Ive installed Mono as described on the official website. If someone has a solution, I would be grateful.
Re: Mono shows code as incorrect
Fri Mar 27, 2020 7:40 am
I don't think your photo shows what you think it's showing.
Doesn't appear to have anything wrong with it to me apart from some missing USINGs.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace ConsoleApp1
    class Program
    static void Main(string[] args)
        Console.WriteLine("Hello, world!");
        Console.ReadLine();
This is a doctor free zone.
JesCads
Fri Mar 27, 2020 6:24 pm
using System;
using System.Linq;
using System.Text;
    class Program
        Console.ReadLine();
Thats what I thought. But on my PC I can write a simple "Hello World program" by only using System and nothing else. I still added all your namespaces. However, it still does not work. The namespaces Linq and System.Text could not even be found. When I hover over the string "Hello World!" for example, MonoDevelop shows me "Predefined type 'System.String' is not defined or imported. Iam also unable to add the namespace System.String it does not exist. I think I need to reinstall my pi or MonoDevelop.
Fri Mar 27, 2020 8:28 pm
You're going to need to post your problem on https://www.mono-project.com/community/ as there aren't enough folks on here who've ever installed & run Mono.
I did for an article in Magpi magazine issue 30 https://magpi.raspberrypi.org/issues/30/pdf as I was testing the code on page 26 before it got published. That was when I got my BMP180 temp & pressure sensor that has now saved me more than £400 in fuel bills.
JesCads
Sat Mar 28, 2020 1:19 am
Im gonna go check out the Mono Community. Let me take a look at your article as well. Anyway thanks for your help. I appreciate it.
Sat Mar 28, 2020 2:09 am
It's not my article, I only tested the code and edited it for publication.
