manjunath
Command and Response UART communication between two Raspberry pi
Thu Mar 26, 2020 12:41 pm
I m trying to communicate between two Raspberry pi using UART (serial communication). One Raspberry pi should send a command and the other Raspberry pi should send data based on command received. Is there a library that we can use for this purpose?
B.Goode
Re: Command and Response UART communication between two Raspberry pi
Thu Mar 26, 2020 12:56 pm
Looks like a 'delete and repost' operation. Which is unfortunate given that a Moderator advised people to respond to your now deleted original post.
pyserial seems to be what you need: https://pyserial.readthedocs.io/en/latest/pyserial.html
I will play no further part in this discussion.
Thu Mar 26, 2020 1:02 pm
Unfortunate side effect of multi-posting, wrong posts get deleted and causes confusion, after 8+ years do not understand why posters feel they get a better / quicker response by doing so....
Posting links again as nothing better to do today:
https://www.raspberrypi.org/documentati ... on/uart.md
https://pinout.xyz/pinout/uart
Retired disgracefully.....
......to an uncomplicated life !
manjunath
Fri Mar 27, 2020 4:12 am
sorry for the repost of this question. beacause the old post was locked. sorry sir. i understand pyserial is helpful. But the thing is that i wanted to know any other library package is available for this which i can directly use?
scotty101
Fri Mar 27, 2020 9:26 am
Pyserial is what you are looking for....
It allows you to send and recieve serial data.
What more are you looking for?
Return to “Python”
